1. remove the cover for the duplexing drawer below the fuser drawer.
2. extend the fuser drawer
3. remove the 3 front covers of the fuser drawer
4. remove the three black screws that secure fuser motor,
5. remove the yellow cover to access then two screws that secure the fuser unit to the drawer.
6. unplug the connectors you see in front and the one below the fuser unit.
7. fully extend the drawer and push in the leaf springs you see and pull the drawer out further
8. remove the two screws you see on the top of the fuser and remove the fuser unit- gently.
Good luck
It sounds like you may need to change it again. These printers use a Teflon coated heat roller in the fuser. If you print envelopes that will scar the heat rolller, this can also happen if there is a piece of paper jammed in the fuser assembly and it scraped the fuser roller. Open the back of the printer and look at the roller in the fuser. I would bet that you see the roller is damaged. Here is a link to a post about the Laserjet 2100 printer with the same issue. It has pictures of the roller and what to look for, the fuser is different but the principle is the same.
Hello, When you first install the printer onto the Network it will automatically find an IP Address, this is called "DHCP". In order to change the IP Address the printer needs to be setup as what is known as "STATIC". You can do this inin a couple of ways 1) Type the IP Adrees into an internet explorer Browser, this should open up the printers EWS (embedded Web Browser) if it opens click on the networking tab - Chnge the IP Address , set DHCP to "OFF"and click Apply. 2) From the printers control panel - push the "MENU" button and scroll down to the "CONFIGURE DEVICE" to "I/O" to "EMBEDDED JETDIRECT" Withi the TCIP setting you are able to change the printers IP Address
1 Unplug the power cable.
2 Remove the paper delivery tray assembly
3 Remove two (2) screws from the right cover assembly
4 Remove the right cover assembly, carefully disengaging the catches
5 Unplug the control panel cable.
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover
7 Remove the upper face cover
8 Remove four (4) screws from the upper cover
9 Lift up and remove the face-down cover
10 Remove the output tray by releasing the tabs.
11 Unplug the harness from the fuser motor
12 Open two (2) clips and remove one (1) clip to remove the fuser connector.
13 Unplug two (2) 3-pin optical encoder wires
14 Unplug the red high-voltage bias wire.
15 Remove the thermistor wire.
16 Remove the cables from the wiring harness.
17 Remove three (3) screws from the fuser chassis.
18 Gently rocking if necessary, roll the fuser forward to remove.
Use the following procedure to replace the fuser.
1 Align the fuser tabs with their respective holes.
2 Complete replacement by following steps 1 through 18 above in reverse order.
NOTE When replacing the right cover, align the tabs on the upper edge of the right cover
and lower edge of the face-down cover with their respective slots.
Hope this helps
