HP Officejet 5510 All-In-One Thermal Printer Logo
A
Anonymous Posted on Jul 11, 2014
How to cancel print job ON HP 7520? - HP Officejet 5510 All-In-One Thermal Printer
5 Related Answers
Anonymous
  • Posted on Apr 10, 2008
SOURCE: HP 2600n can't cancel the last document
SOLUTION!! We have had a 2600n and a 1022n with the same problem as this. Changing the print processor to "RAW" and/or from ZIMFprint to WinPrint did no good in our situation (though I hear it works for Vista clients). We played around with it for several days, researching, testing, trying different methods, and FINALLY - FINALLY! - came across something that worked in both of our situations....
Hopefully, this will work for you as well: On the machine/server where the printer is installed (whether as TCP/IP or otherwise) -- In the printer properties, under the "Ports" tab, you should UNTICK THE BOX for "Enable bidirectional support" -- in other words, you need to disable bidirectional support.
(In case you're wondering, I cannot take credit for this -- I finally found this fix at the following location: http://forums.whirlpool.net.au/forum-replies.cfm?t=916989 ) :)
Anonymous
  • 159 Answers
  • Posted on Jan 19, 2009
SOURCE: Need to clear all printing jobs from the printer 4250 HP
It's probably queued up on the computer you're using. If this is Windows or Mac, look for a printer icon toward the bottom-right corner of your screen.
If you don't have it and you're on Windows, click Start: Control Panels: Printers. Find your printer.
Inside the new screen, you should be able to first pause the printer, then cancel all the jobs. You may have to highlight all of them, then right-click to get cancel.
When they're all cleared out, go back to where you paused the printer, then hit Resume printing.
websnail
Martin Smallridge
  • 419 Answers
  • Posted on Jan 25, 2009
SOURCE: unable to cancel a job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
websnail
Martin Smallridge
  • 419 Answers
SOURCE: printer will not cancel print job
START
Control Panel
Services
Anonymous
  • Posted on Feb 27, 2009
SOURCE: Printer won't stop printing garbage
I had the same problem hooking my old HP Deskjet 812C to a computer running Windows XP with a parallel printer cable. I tried changing the cable to a new printer cable and the printer was immediately detected and installed on reboot. I think my old printer cable might not have been bi-directional.
HP Photosmart 7520 IP: won't connect
Printer offline is a common issue faced by several users. While printing a document, a pop-up notification indicating the printer is offline may be frustrating. No print jobs will execute until you resolve the issue.
If you are also of those users and asking why HP Printer not connecting to Wi-Fi, you got the right screen for the solution.
Read the article for simple instructions on getting your printer back to work.
Why My HP Printer Won't Connect to Wi-Fi?
Receiving an error message on the screen doesn't imply a broken printer.
An offline error suggests that the printer can not communicate with your computer.
Therefore, you must pause all the print jobs and wait until you find the solution.
Check out the reasons that can make your printer offline:
Poor Network Connection
Outdated Printer drivers
Incorrect Printer Settings
2answers
Why does my 7520 printer print old documents.
Your computer has "queued" various pages to be printed.
When it detects that it cannot completely complete the output, it restarts the sending of the information to the printer.
From the Windows "Control Panel", select "Printers".
Select your printer. Click to "show what is printing".
From there, you can select an item, and choose to "cancel" it.
HO C4200 DOCUMENT STUCK IN QUE CAN'T DELETE
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at: http://hpanswers.blogspot.com/2008/10/cancel-and-delete-stuck-print-jobs-in.html#sthash.QD3KNI9q.dpuf
2answers
I entered a print job that I want to cancel. How do I cancel printing?
Click on the printer icon at the lower right hand corner of your screen.
This will bring up the print spooler dialog. Make sure the print job you want to cancel is selected.
You will find the Cancel command in the menu.
Hope this helps.
2helpful
Unable to delete pending jobs
1. Go to Control panel - Printers .
2. Right-click the icon for your printer, and then click
Open.
3. To cancel individual print jobs, right-click the print job
4. To cancel all print jobs, click Cancel All Documents on
the Printer menu.
Alternatively if this doesnt work you have to restart the spooler service
1.Go to Control Panel - Click Administrative Tools.
2.Double-click Services.
3. Stop the service called Print Spooler.
4. Click Start to restart the Print Spooler. Then click OK.
Hope this helps.
2helpful
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
2helpful
2answers
How do I cancel a print job?
just turn the printer off...and delete the commands from the error and job folder...you have to insist ...and try to open it from control panel or Hp in all programs .if it doesn't work from tray system ...this is the way to annul the commands...if it does not want to ..restart and try it again until it get rid of it ...restarting will make it not see that is used by another device ..
My printer hp deskjet 3550 not working properly
my printer did not take the printing job. I wnt to cancel the job but it is not cancell lsat one job is still pending. If acctionally take the print firt two line is printing the rest of the matter is pending and that job is not able to cancel . I have hp diagnostic utility but it is also not working to release the printing que. kindly do needful to solve this problem
Hp deskjet f4140 not operating
Goto start>Run>type services.msc>try to stop and then start print spooler service
k24674
Grand Canyon Tech
Grand Canyon Tech
