SOURCE: Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
SOURCE: Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
SOURCE: SubZero 690: Frost builds up on ice chute flapper door
you have a bad seal, Take a dollar bill and slide it in between the door seal and the frig. slide it up and down to see if if has drag on it. If you find places it dont touch loosen the screws and adjust the hinges till it fits tight. In some cases you might have to tweak the doors if they need it.
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
SOURCE: My subzero 650 ice maker drips water w/o making ice
jackfrost / has given the correct ans to this problem . I belive the new water valve will correct the problem ****
