Question about HP LaserJet 2840 Printer
Hp 2840 error code 49 - HP LaserJet 2840 Printer
Tareq Bin Mostaq
    Habit-Forming:
  • 199 Answers
49 means data transfer error from your computer,please power off the printer and delete all print command from your computer ,try again best luck
Posted on Sep 09, 2016
5 Related Answers
Anonymous
  • 62 Answers
SOURCE: HP 2840 "Engine Error"
engine error is the fact the the printer isnt turning, also may have a fault in one of the circuit boards.
Posted on Jan 10, 2008
Anonymous
SOURCE: HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Posted on Aug 06, 2008
Nikhil Gedam
Nikhil Gedam
  • 87 Answers
SOURCE: hp 2420 error 49 3c1a
If the printer is displaying 49.xx error message, followng the following document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
Upgrading the firmware should resolve the issue.
Please let me know one you perform the above upgrade.
- Nikhil
Posted on Nov 24, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
ERROR 49.FF81
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Mar 20, 2014 | HP LaserJet M3027 MFP Printer
Error Code 54.2 On HP Laserjet 2840
Dear Friend, Its carousal rotation error.. Only professionals can rectify this major problem, I won't suggest you to do this activity, experienced engineer only can resolve this issue..
Mar 25, 2013 | HP LaserJet 2840 All-In-One Printer
Show picture of carousel rotary for hp 2840
Carousel rotation motor error, only professionals can do this activity,, Pl submit the unit in service center,, online support not suggestible..
Nov 16, 2011 | HP LaserJet 2840 Printer
49 error on HP laserjet 3050
HP Printer Error 49 is normally caused by a communications failure between your PC and the printer. If you have an HP printer you may receive the HP Printer Error 49. This is normally effected by a communications breakdown between the printer and the PC, or related file errors.
Check this for Full solution- HP Printer Error 49
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
I have an HP 2840 and I have constantly been getting a scanner error 52 code. Per the text and research they say power it on and off, which did not work. Other experts say to replace the scanner...
hp 2840 error The device HAS Experienced 52 year internal hardware error. theoretically not initialize the scanner, to be replaced after that piece or set of diagnostic scan (logic board or motor, etc.
Apr 12, 2011 | HP LaserJet 2840 All-In-One Printer
Error 49
If the error can be reproduced, use the following sections of this document:
  • Product-specific documentsProduct specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html. Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate errorIf the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific errorThe error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Nov 03, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Hp color laserjet 2840 printer error 49
Printer error “49.XXX” is one of the bugs that can occur while printing a document. It can occur due to a number of reasons including corrupted data, invalid print commands, bad software and loose cable connections. Being a type of firmware error, it is difficult to point what caused the error. The error can turn out to be quite a hassle, because if Printer error “49” happens once, it will most likely happen again. get more information and help from here
Aug 25, 2010 | Office Equipment & Supplies
My hp 2480 has an error message 10.1004
the #10 error codes are supplies memory errors, it's saying toners installed don't match what's in the memory. Could be dirty contacts or generic toners.
Sep 29, 2009 | HP LaserJet 2840 All-In-One Printer
Mar 22, 2009 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Printer Logo
134 people viewed this question
Ekse
efs_perpends
efs_perpends
