Question about Hotpoint Aquarius WMA42 Front Load Washer
Wd420 Door locked light flashing
5 Related Answers
ashburton
  • 417 Answers
SOURCE: HOTPOINT washerdryer WD420
The interlock is stuck, you need to get behind the casing to release. this can be done by taking the top off and reaching down to the door mecanism and pushing the lever open. CAUTION disconnect the machine from the electricity supply before attempting this.
Posted on Nov 04, 2008
Anonymous
  • 9 Answers
SOURCE: door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Posted on Apr 04, 2010
Anonymous
SOURCE: door will not open on hotpoint wd420 washing
Turn off the power and isolate the water supply, Move the machine in to the middle of a room - you need some space. If you then rock the washing machine backwards, there is a door release. It's extremely hard to reach, about level with the lock, so make sure the machine is both stable and that someone is with you to ensure the machine doesn't fall and crush you to death!
It basically looks like an little electronic panel, in the middle of which you can see a steel knoble. Press with some force, and the catch will release.
This just happened to ours, and the actual lock is broken, so that was why we couldn't open the door. Yours might have a similar fault. The mechanism is partially plastic and it looks like the plastic sheared off and then the electric release no longer pulls the catch in to the position where it will release.
Posted on Dec 08, 2010
Anonymous
  • 6277 Answers
SOURCE: I have the hotpoint wd420 the dry light keeps
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 09, 2011
ruxs
SOURCE: i have a hotpoint wd420.
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Posted on Jul 24, 2011
All lights flashing and can't use the start button.
This could indicate a faulty door interlock switch, Cost of parts around £20......Simple to fit...
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
3helpful
Door stuck shut hot point wd420
My aqurius WD420 shows that the door is locked. So i can't open it........
If the door will not open normally, then the only solution is to remove the top cover, and force the door open from inside the washer at the front
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
We have a hotpoint wd420 washing machine and it wont finnish a wash cycle. wont drain the water either, we do get an error code though in that the door locked light flashes as well as the reduce creases...
you have a blocked pipe - where the water is draining out. Either that or your filter is blocked.
best you open the back and take a look at the filter before calling out hotpoint - might save you 100 pound call out charge.
Hotpoint Aquarius WMA42 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
Paul Carew
Vernon Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
