Question about Magellan RoadMate 700 GPS Receiver
Does not reset location
Magellan Roadmate is frozen on last used location.When I power up it does not show current location.
Posted by munch22 on
  • Anonymous Nov 11, 2007
    My Magellan 700 and 760's have the same problem. Will not reset or pick up satellite signals. Sometimes takes 10-15 minutes. Can there be a problem because they were near magnets and if so can this be corrected.
Anonymous
    Problem Solver:
  • 20 Answers
I too have sometimes to wait for 20 mins before my Roadmate picks up all the satellites it needs. The problem is worse if I'm surrounded by buildings.
I have at last decided to bin the Magellan as it's been nothing but trouble and Magellan Support just don't seem to care to respond.
Am now getting a Tomtom Go series with all preloaded, maps/ traffic/ cameras - it auto updates each time it's put on its cradle attached to PC/internet.
Posted on Jan 08, 2008
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
My gps is frozen since ysdtay night.I t shows no movement n its frozen stating univeristy bld.What do I do??I just got it last month & did not buy the protection plan for it..What is the problem
mine was frozen 2. i called support and they helped. first hold the button 2 turn it off for 10 sec. reboot if u had trip ie. address programed in cancel it. That worked. Also not sure if this had anything to do w/ it but my battery was low and the gps powered off. I then plugged it in to the car charger this may have rebooted my gps. It now works fine.
Jan 17, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Magellan 315 frozen
Occasionally, a unit will need to be reset. This can be due to software errors, firmware updates or simply at the command of technical support staff. A reset either will restart the unit, possibly clearing up any minor errors, or will restore the unit to the settings it was built with. There are three major Magellan units, which utilize different methods to perform this task.
Things You'll Need:
  • A thin object (such as a paper clip)
Using the stylus, tap "Main Menu" and select "View."
Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
Tap "Confirm," and the unit will begin to reset.
Maestro/Roadmate GPS Units
Locate the button marked "Reset" on the left, right or bottom of the unit.
Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Tips & Warnings
  • Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
Jul 20, 2010 | Magellan GPS 315 GPS Receiver
I need a reset
assuming you have this in your car and not in your house, turn on your 360, after it boots, press and hold the power button for 15 seconds (do not let off the power button when it shuts off, keep holding it for 15 seconds.
once its off, press and hold the power button until it starts, then give it time to aguire the satellites.
if that fail, it might just require an update...version 1.81 can be downloaded HERE
bill
Dec 13, 2009 | Magellan RoadMate 360 Automotive GPS GPS...
Frozen screen on Magellan RoadMate 2200T
Press the button to turn it off but hold it for about 10 seconds. Let go and then press it to turn it on. This resets it.
May 22, 2008 | Magellan RoadMate 2200T GPS Receiver
Frozen screen
I have a Solution for this Problem,
i have a Software
Any need this contactme i don't know how to post the file,
Fabian
Apr 25, 2008 | Magellan RoadMate 800 GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
455 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
