Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
A
Anonymous Posted on Jul 10, 2014
Why the Plantronics Savi W710-M red light will not turn off
How do I auto answer using Plantronics Headset (Savi W740) on a Mitel 4250 Phone?
Plantronics makes an adjunct device that attaches to the telephone base (Velcro) and can lift the handset when the button on your headset is pressed. Unfortunately that's the only way to directly integrate the Plantronics (or any other brand) headsets with the Mitel 4XXX series phone. This handset lifter is actually bundled with some of the SAVI headsets, depending on the actual model you get. Separately it's about an additional $50 option. I recall the Plantronics part number is HL-10. Hope this helps.
How do you auto answer using a Savi W740 Handset on a Mitel 4250 Phone without pressing the Multicall Button?
You neet the Plantronics HL-10 Handset Lifter kit. Sold bundled with certain SAVI models and sold separately for approx $50. Contact your Plantronics dealer else get it from Amazon
Why is there an echo when using wh210 headset?
Read owners manual some blue tooth devices can change channel, much like TV stations. Or unpair both devices and use a different good known controlling device and pair pair with it. If same issue persists, throw in trash and buy a quality unit. No substitute for g good quality electronics. Motorola makes almost all the semiconductor components that make every electrical devices internal components. Therefore they know how to wire which ones the best cause they built it. Can't ever go wrong. Now its a Google owned company. Which is american. Buy from the red white and blue
I’m happy to assist further over the phone at https://www.6ya.com/expert/christpher_f760d0f18f8eedc3
My m100 bluetooth always calls the wrong person.
Plantronics M100 always calls the wrong person:
Unfortunately this is a common occurrence. We say one name and it says, "did you say..." something totally different. I think that most of us has had that experience. The Bluetooth headsets that have a longer "boom" type mic will pick up your voice better and have a better chance at hearing your voice properly the first time. Models like the Plantronics Voyager Pro+ and the WG100/B have a boom type microphone. The WG100/B also includes a UBS Bluetooth adapter so it can be used on a pc.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/computer-mobile/wg100-b-savi-go-wireless-headset-mobile-computer.html
Good luck from Headsets Direct - 800-914-7996.
3helpful
Savi Office WO100 won't charge. The green light on the base is blinking but my computer says there is 0% percent charge.
There are two possible solutions to this issue:
1. The headset needs to be reset.
2. The headset is defective and should be replaced.
To reset the headset, use a straightened paperclip to push the reset button on the inside of the headset, below the earhook. See the pic:
You may need to hold the reset button for a few seconds. Then replace the headset into the cradle. You should see normal behavior again.
If this doesn't work. you will need to replace the headset.
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
1helpful
Cant get the red light to turn off
Try powering down your bluetooth then turning it back on. If that doesn't work, try charging it. I had the same problem with mine.
Top Insignia Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
