Question about SanDisk 2GB microSD Memory Card
My apacer micro sd 32gb card is undetectable - SanDisk 2GB microSD Memory Card
Anonymous
Try using a different program to format it. It may then show up.
Posted on Aug 17, 2014
3 Related Answers
Anonymous
SOURCE: pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Posted on Jan 05, 2009
Anonymous
SOURCE: Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
Posted on Jun 15, 2009
Anonymous
SOURCE: To unlocked 2 gb micro sd card
i miss my memory caed password how to opena
Posted on Jan 04, 2011
I just got a zte n817 phone want to get a 32gb micro sd card will it be compatable with this phone
That is kind of an entry level phone. You better stick with a 8Gb or max 16Gb micro SD. When the card fills up, the device slows down and that is a pain. So, try to get a class-10 micro SD if you can.
Jun 08, 2017 | ZTE Cell Phones
While being formatted, why is 'THE PARAMETAR IS INCORRECT' displayed?
You typed a space where there should be none.
Example: Format D: / . Should be Format D:/
Mar 05, 2016 | Kingston Digital Sd10/32gb 32gb Micro Sdhc...
My pad says the internal storage is almost used up...I inserted an sd card, but not sure how to get the tablet to read it so that I'm able to install more apps and games.
Good afternoon Linda!
You can view your manual here
RCA RCT6077W2 Manuals . If you go to page 10
RCA RCT6077W2 User Manual Micro usb Headphone Micro Sd it notes a couple of important caveats on the card:
  1. You can use MicroSD or MicroSDHC type cards
  2. Size limit of 32GB
  3. You are warned never to insert or remove the MicroSD card in 'On' mode (i.e. only insert/remove the card when the tablet is off)
Aside from that, it looks like things should work. To be sure on what is the root of the issue, you can:
  1. Insert your card into another device to verify that it works
  2. Format or Re-Format the card - the SD Card association has a formatting app here:
https://www.sdcard.org/downloads/formatter_4
  • Make sure the card is legit. If it was purchased, for instance, off of Ebay, or other not-so-top-tier online store, as likely as not it's a fake made in China, likely with guts from manufacturing rejects. You might, for instance, get a card marked 32Gb that actually has a 2Gb chip in it with a hacked controller that says it's 32Gb. It'll seem to work OK for a few files, and at some point will just write your files into no-where. SD Insight, a free checker app for Android phones can be picked up here
SD Insight Confirm your micro SD card authenticity instantly amongst many options.
Hoping this helps!
D
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
What type of sd card do i need for a LG ULTIMATE 2
It can handle an SHDC also. I have one in mine. Just pick up a MIcro SD card up to 32gb. I picked one up on Amazon for 12 bucks. Works great. Amazon com micro 32 gb sd card 0 15 Memory Cards Cables Accessories...
Mar 05, 2015 | LG Cell Phones
My Huawei ascend w1 (windows phone 8) is not reading or even registering my micro sd memory card
micro sd card can fail i've had a few work on a pc but not the phone. 32gb one are more prone to do this. try a different sd card if it works then its down to the card it self if not read a know working one then somthing has hapend to the sd card reader. may have some muck in there stopping it working. or the board has faild.
Sep 13, 2013 | Computers & Internet
Insert sd card camcorderst recognize any micro sdcard
If your SP1 camera cannot recognize the micro SD card, please be sure you are using a card between 4GB to 32GB, class 10 speed. If possible, please try another micro SD card to be sure that the card that is not recognized is not defective. If you are using a card with correct specifications and it is not recognized, then the micro SD card port on your camera may be defective. Please contact Intova directly via email: [email protected] or call us at 808-837-0074 for customer service/warranty coverage. Thanks.
May 28, 2013 | Intova SP1 Sport Pro 12.0 Megapixel,140...
16gb micro sd transend undetected by all devices
Hey friend its of no use how many methods u do try there's no way that your memory card is gonna be fine again its cause u may be using it to much or u may be using it to get more and more things from bluetooth happened to my 32gb transcent card toooo
Oct 11, 2012 | Transcend Information 16 GB Micro SDHC10
Why 32GB micro sd tf memory card only US$98.00? check the link http://www.onthesource.com/32gb-micro-sd-tf-memory-card.html
I believe this company is located in China. Their website states that their products aren't brand name. My advice, buyer beware.
Jun 11, 2010 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Apacer Micro Sd (adaptor) not read by computers.
well i would see if you have the updated drivers for the card reader.. if not it might be a older computer that is not savy with the new high tech stuff we have today.... i hope this helps.... let me know
Jul 31, 2009 | BFG Technologies GeForce 7800 GTX OC ,...
SanDisk 2GB microSD Memory Card Logo
103 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
