first off, its is NOT 3 years, old, new to you but not new
not in the slightest is it NEW> in fact 2002 monitor !!!! oops get ripped off by fibbing sellers, that it?
and it is bad.
NO PC stated.
NO OS stated
and no photos of bad, screen.
strike 3 you are out, like the 100000 post here like this,
no inputs, and expects magic answer from the blind, SSDD.
the name COMPAQ ended in 2013, 4 year ago.
most CRTS ended in 2013, started in 1981 with IBM MDA.
Monochrome monitors. eeks.
so why not buy a real LCD LED monitor 2010 and newer.
and join the 21st Century VACUUM FREE, and dangerous
19,000 volts free too (1kv per inch) it can kill you,
don't spill drinks in the top ok and live another day.
(PS; worked this from 1965 to 2010,) even NAVY PPI monitors huge. so know monitors well I do.
100% free and Zero steal email from you .
https://www.manualslib.com/manual/273744/Hp-Compaq-Cv5500.html
RTM all there is is this RTM and play with knobs.
What is so wrong here, is no PC stated.
monitors this old do not work on modern PC, unless you learn how to do that. (skill sets that)
step one set PC to 800x600, (screen reso)
then plug it and and pray the CRT brain works. still
that is all there is to it.
power on PC set to 800x600 reso
power on CRT.
push left select button (spoon fed)
see no signal on screen, means PC is dead. signals on vGA jack.
see out of frequency, message , see 800 above.
that book stinks btw.
lets find others.
MV9500 right, MV missing on your first post why?
the 9500 , no mV is here.
it does have OSD screen , push select button
https://www.manualslib.com/manual/30062/Compaq-7500.html?page=15#manual
degause it,
move screen L/R& UP/DN
and shapes, I call it trapezoid changes.
bright and contrast , no magic here all SOP,
max RESO on this old pig is.15yo
is 1024,x 768 60HZ
over that as most PC do now, this PIG GOES NUTS> fails.
