Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
AFTER READING ON UR SITE IT APPEARS I NEED A CONVERGENCE KIT. MY SCREEN IS ALSO GREEN, NOT ORANGE AS I HAVE READ FROM OTHERS. EVERYTHING IS DOUBLE AND BOWED AND LOOKS 3D.
SOURCE: problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 03, 2008
SOURCE: Philips 55pw9363
I have to suggest a solution for this problem. I sell tv's for a living. Never buy a philips projection TV. Fortunately you can't anymore, but don't ever think about buying one again.
Posted on Apr 30, 2008
SOURCE: colors night lining up
Your symptom sounds like at least one damaged convergence IC.
If you have a good low wattage soldering iron ~ 45W (available at radio shack) you can perform the repair yourself, and this will most likely take care of the entire issue.
I like to remove the board that the IC’s are on so that I can unsolder the connections and clean then up using solder wick (this is also available from radio shack). Removing the board is not a real issue as the connectors are all labeled with an alpha number, so that you can connect them back real easy. There are three in the middle towards the front that I like to mark with a sharpie as they are the red green and blue convergence coil connections (they are all the same size in a row). Just mark them with slashes, like I, II, III, or something like that. If you mix them up it is not a big issue, you can test swapping them around until the picture lines up.
Please be sure to remove the entire white heat sink compound on the heat sink and apply an even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
This repair from a good technician will normally run from $250.00 - $300.00, and sometimes more depending on your area.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10.00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Aug 12, 2009
SOURCE: Our Philips Model # 51pp9303H/17 TV has alot of
Yea its a convergance issue. I'm more familiar with the sony bigscreens. The convergance amplifier number for that one is STK392-120. The schematics show that your tv has two of them.
Go here for a service manual: http://www.eserviceinfo.com/downloadsm/31487/Philips_DPTV305.html
You will see a window that says file information, at the bottom you will see something that says multipart 0 1 2 3 4. You need to download all of those files. you will also need WinRAR to unzip them. You can download a free trial of winRAR.
Once you have WinRAR and the files open part1.rar and it will unzip everything into a 1800 page pdf that is the service manual.
If you have a work copier use that to print the manual or use the pdf search function to locate the STK392-120, or 7044 and 7055. The latter two numbers are the numbers philips uses to identify the chips in their schematics.
I know its a lot of info, but I hope it can help.
Posted on Aug 25, 2009
SOURCE: PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
I have a philip magnavox 60" screen. My problems is when you turn the TV on there is a oral circle with a blue color on the left side of the oval and a red color on the right side of the oval circle. When the TV get warmed up it goes back to a full screen. Could someone tell me what is my problem and how can I fix it and where can I get parts to fix it. My model # is 9p6040c101. Thanks Robert
Posted on Nov 12, 2009
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Oct 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Aug 27, 2009 | Televison & Video
Jun 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
May 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Apr 12, 2009 | RCA HD61W66 61" Projection HDTV
Jan 24, 2009 | Philips 43PP9202 43" Rear Projection...
Oct 30, 2008 | Philips 60P8342 60" Rear Projection...
Sep 10, 2008 | Sony KP-51WS520 51" Rear Projection...
Jun 28, 2008 | Philips 9P6444C 64" Rear Projection...
Jun 20, 2014 | Philips 60PP9202 60" Rear Projection...
