Hi I am vortash The user maual you require is available on the following link free http://www.safemanuals.com I checked and just downloaded it myself so if you do have problems return here and I will arrange to transfer it to you .. Regards Vortash
Thanks Mike.
Yes it is the same.
Make sure that the timer is set to manual, and not on auto or the oven will not work..
It should tell you the procedure in your user instructions.
Plz rate my solution.
thanks.
I remove the whole hinge and top from the back put the old hinge on the new top then move the burner to the new top put the whole hinge on the back of the oven.. hope is is a little help
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
