I've pulled up the user manual for your phone. Thank you for providing the phone make and model first, and the complete description of your issue!
The manual says the battery should be charged for 15 hours before first use.
You may be set to pulse dialing , even though the factory default is for tone dialing. If you push the 7 key, you would hear 7 pulses or clicks in succession. The dial tone will be gone once a pulse has been received. And you say there are clicks heard and no dial tone.
You can set Handset settings (Page 12 in the PDF copy) and customize how your phone works.
Hit MENU and use the up-arrow and down-arrow keys to scroll to the desired feature., this time called DIAL TYPE, then his SELECT. Looks like the sixth menu entry from the top after LANGUAGE.
It should read:
DIAL TYPE
TONE
If it says something else, perhaps PULSE, use those arrow keys again to change the Dial Type to Tone. Then use OFF to back out of the selection and again to clear the menu.
Attached is the link to the manual. Click the button on the screen to "Open as PDF" and you can open it in your PDF reader software or save it to your device for offline reading.
http://phone.manualsonline.com/manuals/mfg/att/e2125.html
