Xeroxhttps://www.support.xerox.com > en-us > article
Jan 19, 2021 - Resolve the Duplicate IP Address Conflict With Another Device on the Network. Manually Set a Static (Permanent) IP Address on the Embedded ...
Copytechnethttps://www.copytechnet.com > ... > Xerox
Aug 30, 2014 - This error code means your bustled Fiery or Creo network controller do not communicate with the machine. Check all cable from net controller to ...
Printcopy.infohttps://printcopy.info > code=027-452
Code: 027-452; Description: IPv4 Duplicate Duplicate IPv4 addresses detected upon startup. Causes: Remedy: 1 At the printer's Control Panel, press the Menu ...
You are right, the feedroller is worn and needs to be replaced. Is your copier in an office or your home? Is it a copier bought by you personally or by your company? The reason for that is, Xerox never sells copiers to businesses without pushing a maintenance agreement on the customer. With that, there is an 800 number in the user manual for service and sometimes the number is posted on the copier. Unless you have a tech available to order and replace parts, you will have to call Xerox.
