Question about HP Officejet J5780 All-In-One InkJet Printer
Why 4610/4620 received failed incoming fax - HP Officejet J5780 All-In-One InkJet Printer
5 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: receiving a fax
Faxes fail intermittently or with only one fax number
  • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
  • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
  • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
  • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
  • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
  • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Posted on Nov 12, 2007
dewan nafees ahmed
  • 1894 Answers
SOURCE: fails to receive fax
i think this can be a problem in your FAX unit alone.
may be due to some disturbances in line
Posted on Jun 10, 2008
Anonymous
SOURCE: HP Officejet J5780 incoming faxes
Can fan from window only.
Posted on Jan 14, 2009
Anonymous
  • 6 Answers
SOURCE: My HP J6480 All-in-One will fax out but I can't
look for auto answer button and press it .make sure the light is on .do one thing if the machine detect a fax tone press the start fax button. if it doesn't help then you need a fax module.
Posted on Jul 14, 2009
Rider On Way
ONE-Touch-Solution
  • 1679 Answers
SOURCE: No Incoming or Out going Faxes Out going faxes
Press Setup Button on front panel of printer
Scroll to Fax Settings ( Or Advanced Fax Settings )
You will find ECM ( Error correction mode )
Turn it OFF
Try to receive Fax, IT should work
Posted on Jun 25, 2010
Not receiving faxes
please replace with new original cartridge to solve this problem.
Aug 28, 2014 | Canon ImageClass MF-8050CN Multifunction...
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Turn it OFF
Jun 25, 2010 | HP Officejet J5780 All-In-One InkJet...
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Receiving a fax
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
48 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
