Question about Toshiba MR120 Remote Control
What is the code for a chunghop remote control rm-139es
1 Related Answer
Anonymous
SOURCE: code for chunghop rm-88e remote control
code
Posted on Jul 17, 2010
I have a tv set make Hisense 32 inches . I bought a universal remote control RM-139ES but the 'set' key does not illuminate when I hold it. Please help me d
0281,0188,0183.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 25, 2014 | BuySKU CHUNGHOP RM-139ES Universal TV...
Remote control code for matrix
Aug 16, 2014 | BuySKU CHUNGHOP RM-139ES Universal TV...
CODE FOR TV PANASONIC, CHUNGHOP RM 139ES
020, 001, 002, 014, 015, 021, 022, 059, 066, 423
Jan 23, 2013 | BuySKU CHUNGHOP RM-139ES Universal TV...
Chunghop RM-88e Thomson code
Click here to download the user manual to your remote control. It has all details.
Nov 07, 2012 | none CHUNGHOP RM-139EX Universal Remote...
Code chunghop RM 139ES for TV Hyundai
Google the model number of the remote for manual to try to locate possible codes here.
Not all remotes will program and if do likely will not have all needed features the original remote does.
Jun 14, 2012 | Televison & Video
Chunghop rm-309es code for Sony
Check these codes:
0128 0013 0002 0071 0380
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
May 12, 2012 | Universal Remote Control Remote Control
I have a chunghop rm-309ES universal remote. I lost it's codes. My TV is Panasonic. Can you give me the codes so i can use my remote again and can you teach me how to set the codes. Thanks. :)
Hello
Codes for Panasonic with Chunghop RM series remote control are:
0001/0003/0019/0037/0040/0106/0110/0111/0112/0114/0190/0212/0241/0711/0745/1036
If you are in need for a three digit code; remove the first Zero from each code and take the rest three digits.
Eg: for 0001 [four digit code] (001) is its three digit code. OK.
Jul 11, 2011 | Universal Remote Control Remote Control
Code chunghop RM 139ES for TV Mitsubishi?
The Mitsubishi TV codes for this remote are 011 and 051.
Programming instructions:
1. Switch on the TV
2. Press the "SET" button in the top-left corner of your Chunghop remote until the LED next to the "SET" button illuminates.
3. Enter the first code above 0 1 1 using the numerical buttons on the remote.
The LED next to the "SET" button will go out if you have correctly entered a code.
4. Test the remote with the TV. If it doesn't work - or doesn't operate the TV functions as you would expect - repeat the above steps for the other code.
Please note: Not all universal remotes will work with all TVs.
If the codes above don't work please post back for further assistance. It may be that your remote wont work with your TV or you may need to run the code search feature of the remote to find the correct code.
Hope this helps.
Regards,
BElectric
Dec 30, 2010 | Televison & Video
Toshiba MR120 Remote Control Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
