Question about Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel IW 712AU - Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel IW 712AU Top Load Washer Fault Code 130
this is usuallt the R.P.S which is locked on the motor take off plastic cover by un doing centre nut loosen stator pull forward a little and remove stator
Jul 10, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher and Paykel Intuitive Eco led lights are flashing by chance the start screen might come up when i start the cycle the water runs into machine for about 3 seconds then it shuts of and the bowl st
The display screen clicks in.
Use a flat blade screwdriver to unclip the display.
Two low profile electrolytic capacitors need to be replaced,
Is a common problem in IW LCD display boards.
Mar 13, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Turns on & off intermittantly at will
It's a motherboard power supply issue.
Is your board part number IW SD11 420093
These boards have that problem. let me know.
Jan 29, 2013 | Fisher and Paykel Aquasmart wl80t65c
Hi I have a fisher and paykel clothes washer model WA75T65GW it is displaying what i assume is an error code. green lights 3 and 4 light up along with red light 8 and it beeps continuously. Could you...
(00011001) Phase 5 IW - LCD Initialisation Error
The Intuitive Display has detected a problem with the LCD. Liquid Crystal Display
Primary Source: IW Display Module
Action: Replace IW Display Module
Oct 28, 2012 | Washing Machines
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
85 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
