Question about Sylvania Scm2401 Curtis Lcd Monitor 24" Widescreen Hd
Monitor will not turn on and power light blinks blue
Bob Sloan
  • Sylvania Master
  • 2,013 Answers
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Posted on Jul 30, 2014
2answers
How to turn off monitor onn. THe blue light flickers when the computer is turned off. Is this normal
I have this monitor too. It just blinks to let you know that you forgot to turn off monitor after your pc is shutdown because it’s the monitors power is still on just like similarly like a tv. Just close the monitor after using pc and it’ll stop blinking.
Samsung syncmaster 2220 blinking blue light and no image display
Good luck.
I have a hp w2207 flat screen monitor. when turning power on, power blue light blinking and no picture. what can I check or look for to find and fix the problem?
That blue blinking light could be the fact that there is not a signal from the PC to the monitor itself. You could have lost your video card, corrupt driver for video card or monitor. If you have a PC with separate video card and a mother board video output, try switching to the one you are not using and rebooting the PC
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
1helpful
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
2helpful
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
1helpful
HP vs17X monitor blue power ligth blinking, nothing on screen
Sounds like a power surge fried the electrical connections inside.
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
LCD Monitors x7g troubleshooting
Check some of the other posts as it is probably just a bad capacitor or two and very easy to fix if you can do that sort of thing. I did and mine is back up and running.
Sylvania Scm2401 Curtis Lcd Monitor 24" Widescreen Hd Logo
Top Sylvania Computers & Internet Experts
Mike
WTF Chuck.....
WTF Chuck.....
Paul Bade
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
