I need to find out why my sears kenmore sewing machine model 15551 does not sew stitches. Everything is threaded properly. what do i do?
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to
find many recently. sewusa.com has some older ones for free. but not
many. you could try the kenmore site as well, if not I'd try to search on
dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
SOURCE: I have a Kenmore 14 stitch sewing machine that I
take out the thread and bobbin. run the machine with the pressure foot up and watch the feed dogs (toothy things under the pressure foot that move the material through the machine). if they are not rising up above the plate, then you are sewing multiple stitches in one place and that's what spools up the threads. take the plate over the feed dogs off (it just pops up). get someone to remove the two screws holding the feed dog on (it's a torx #10). the piece the feed dogs was screwed to rides up and down on a short piece of polished rod under it. the rod has gummed up to its bearing. bright light, look for this and get some oil (3in1) on the rod above the bearing and force the feed dog mount up and down until it frees up.
