Black & Decker String Trimmer Cordless 12" 18V Logo
A
Anonymous Posted on Jul 10, 2014
How long battery last, while using it
Model#nst1118,nst21118
I HAVE SONY WALKMAN NWD-B103F- BATTERY DOES NOT LAST FOR 10 MINUTES-AFTER CHARGING ON COMPUTER
The battery does not hold charge. It is weak. Replace it with same type number. Brand name of the battery isn't a matter, check its type number printed on it.
I have an ion ipa56c block Rocker. The battery is brand new. It gets a full charge and only last a few hours . Help
Block Rockerâ„¢ Bluetooth iPA56C - ION Audio
www.ionaudio.com/products/details/block-rocker-bluetooth-ipa56c
Block Rocker Bluetooth iPA56C provides up to 75 hours of on-the-go sound with its long-lasting ... A high-quality microphone is included to get you started.
RE: Block Rocker Bluetooth model differences - Ion Audio ...
community.ionaudio.com/ion.../block_rocker_bluetooth_model_differe...
Jul 6, 2014 - IPA23 - Explorer Bluetooth, Block Rocker Bluetooth, Block Rocker ...Besides the addition of another bluetooth port and the 75 hour battery on ... Bluetooth models IPA56B or IPA56C..... and between the last 2 what the differences are ? ... I have a model that says it's a iPA56B but only has a 50 hr. battery life.
Amazon.com: Ion Audio iPA56D Block Rocker Portable ...
www.amazon.com > ... > Karaoke Equipment > Players
Amazon.com, Inc.Amazon.com: Ion Audio iPA56D Block Rocker Portable Bluetooth Speaker System ... I work at gm and have bought 4 bluetooth speakers before this one for work use, ....block rocker battery power lasts only a few hours and blue tooth stopped ...
Amazon.com: ION Block Rocker Bluetooth Portable Speaker ...
Amazon.com, Inc.Ion Audio iPA76A Block Rocker Portable Bluetooth Speaker System with ..... I work at gm and have bought 4 bluetooth speakers before this one for work use, All of .... block rocker battery power lasts only a few hours and blue tooth stopped ...
ION Audio Block Rocker, Job Rocker, and Tailgater - Battery ...
noterepeat.com > ION > Portable Audio
The battery life for the remote for my Hampton Bay fan, Model cf556br-crk only lasts 3-4 weeks. It is 12 volt and should last longer. Any solutions?
More info,please.
there are always solutions to a problem. Usually 4.
I have to dig around the internet to see what batteries these take..
Hold on.
The remote control takes 4 AAA cells.
Try Energizer E2 batteries. They are the longest lasting batteries available.
Lithium.
If the remote dies in 4 weeks or less,the remote is at fault.
Probably a factory recall for those remotes.
Try pulling one of the batteries out when not in use.There may be a power drain,internally ALL of the time.
Hi I have had this camera for a short while, its been working fine, lately i put new batteries in, and it only last for and it tells me low batteries only after a short while, has there being an issue with...
Digital cameras often use batteries quite quickly especially with heavy usage. If you are using standard all purpose batteries you may consider using batteries which last longer in electronics that draw a lot of power such as Duracell PowerPix or Energizer Lithium. Alternatively you may consider investing in rechargable batteries and keeping a spare set in your camera bag.
Jul 28, 2011 • Cameras
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
I am using Maxell CR2032 in my computer having Gigabyte Motherboard Model Name: GA-GS31M-ES2L. The cell lasts only for 30 to 45 days.Normally celle/batteries lasts for years in computers. Kindly provide...
Hello sellagiri
You are right. These batteries should last years.
Your problem generally indicate faulty main board. there is a leakage that drains the battery.
Check the assembly of the computer. Make sure the main board is properly assembled and soldering and joints are not in contact with the case, there is no wires from the case touching the battery or its contacts, remove the battery and clean its housing.
Other than these it usually means faulty board.
Good luck and thank you for using Fixya
2helpful
2answers
My cousin gave me his old Dell Lattitude C840. I found when I tried to run it without plugging it in to an outlet, the power only lasts 1 hr 15 min! Is that normal for this model? Is there a solution so I...
Yes, it is normal for this model. 1hr 15min is usually the normal duration that the model of this type of battery lasts. This highest it might go is 1hr 30mins. It's usually difficult for laptop of these kinds to stay 2hrs or more using battery.
There is no solution to this. You have no choice than to continue using it that way.
You are even lucky because some don't even last up to 1hr.
I hope I have answered your question.
Yours sincerely.
Elect_Comp.
How long the lithium batteries last for Conair Model WW60X?
Lithium batteries should last about 3-5 years. That really depends on the amount of use, the way the unit is stored and even things like temperatures. If you replace the battery you need to make sure that the battery is fresh and not old stock. Thats another thing that will cause premature battery death is old stale batteries. Unfortunately the original batteries tend to fall into two types, better than you can find or a lot worse. If you are using the scale a lot ie several people using it then the batteries will also drop off pretty quick. Even in heavy commercial use the batteries should be good for well over a year.
Battery wont recharge how long do they last and can i get a new one? battery model bat-09. Player is pdv-709 9" portable dvd player.
The litium battery should last u about 3 and 3 1/2 years.The minium used about 4 1/2 hours a day,about 3 times a month.Tries Websites Amazon.com,Ebay.com should have this Litium battery.
1helpful
2answers
Battery always going dead use 4 regular lithium batteries
in this camera and most of fuji AA batteries, the batteries keeps draining even with the machine off .
if the camera is not on use REMOVE the battries.
i will recommend regular recghargable batteries with at least 2700 Mah type NiMH.
you can recharge them several times and they will last almost as those lithium batteries on that model. plus they will be cheaper
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
