Question about Sewing Machines
Singer 7463 I removed needle plate how do I put back?
Debbi's Sewing Machine Repair
  • Sewing Machines Master
  • 7,365 Answers
Here is a link for a free manual, the information should be in it http://www.singerco.com/uploads/download/546_7463_efs.pdf
Posted on Jul 28, 2014
1 Related Answer
yeroc
Custom Exchange
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
How do i replace the needle plate on a singer 7463
I found the instruction manual for the Confidence 7465 on Singer's web site available for download. This should be in there. The URL is: http://www.singerco.com/products/1497/7465-confidence#type-resources
Feb 13, 2015 | Singer Confidence 7463 Computerized Sewing...
You can buy a replacement at Sewing Parts Online, and here's a direct link to the part. It costs $15.00 Needle Plate Singer 051099
How to adjust M5 Screw on Singer 7463
What makes you think your timing is off? What is it doing/not doing that makes you think it's off? Before you do anything ,make sure your needle is all the way up in the clamp. A needle inserted too low--even a little--can cause the same symptoms.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
Singer 7463
Check manual for proper threading and insertion/orientation of needle. Or...needle damaged.
Aug 09, 2014 | Singer Confidence 7463 Computerized Sewing...
How do i drop the feed dog on singer 7463 confidence so i can free motion sew?
You cannot drop the Feed Dogs on a 7463 Singer. It should have come with a small black plastic shied that will slide over the Feed Dogs and clip into the two holes in the face plate to cover them completely. If you've lost that dark plastic plate, you can also tape an index card over them, or a piece of thin plastic (like template sheets) to get the job done.
May 20, 2012 | Singer Confidence 7463 Computerized Sewing...
Singer confidence 7463 all lights flashing
try
rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or thread
make sure bobbin is inserted correctly & that it's not damaged
try changing the needle
Singer Confidence 7463 - needle is knocking - bobbin wont thread...machine doesn't stitch - not even 2 months old
Have you changed the needle since you purchased it? A needle should be replaced every 4-6 hours of stitching so for each garment sewn as a rule of thumb. So try replacing the needle, cleaning and oiling the maachine as per the manual. Check needle is in the correct way, it is easy to put in backwards if you aren't familar with them, flat shank to the back and there is usually a scarf (cut away area) at the back of the needle which is where the rotary hook under the needle plate comes around to catch the upper thread during the stitch process. So if needle is in backwards this will cause stitching to fail.
So elimate the needle firstly.
If this fails and the knocking noise continues, then it could be that the timing has been knocked out. It can happen if you sew over a pin and hit it hard (or the needle strikes the foot if stitch setup is wrong for the foot being used). In this case, you'll need to take it back to the shop for the serviceman to fix.
Mar 02, 2011 | Singer Confidence 7463 Computerized Sewing...
Just got my Singer Confdence 7463 and am in the process of threading. I can't seem to get the thread take up to stick out from the machine enough, as I move the needle up and down, to be able to put the...
try opening the light cover door, some have a hinge at the back & others have a plastic plug you can pry up carefully with a small screw driver, that way you can get access to the thread take up lever.
Oct 26, 2010 | Singer Confidence 7463 Computerized Sewing...
How do you attached the darning plate to sew on buttons?
Raise the needle and presser foot, and position darning plate onto
the needle plate with the two pins on the back inserted to the holes on the needle plate.
Sep 27, 2010 | Singer Confidence 7463 Computerized Sewing...
Sewing Machines Logo
191 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
