ROLEX
SOURCE: Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.
Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works.
So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here.
Hope this has helped.
Doug
SOURCE: i wanna sell my rolex daytona ad 1992.. how much i
Be sure to sell it to the right buyer. You can count on webuywatches.com. They buy Watches every type of watches. Quality and safe handling of your timepieces shall be guaranteed. Get the money you need, fast, easy and secure.
SOURCE: i have a' rolex oyster perpertau
i have a' rolex oyster perpertau superlativechronometerofically certified cosmograph' watch with an inscription on the back'winner rolex ad daytona 1992 24' is it a genuine rolex and if so what is it worth.thanks curtis and the date pointer came out from it place how to fix back?
SOURCE: we are trying to figure
There are a few things to check..
Most reproductions/fake Daytonas have a second hand that moves.. if your second/sweep hand is moving like a standard second hand.. you have a fake.
The real Daytona's second hand remains at the 12 position as it is part of the stopwatch function and only moves when activated.
A few other things you can check.. if the three mini dials refer to months or days it's a fake.
If anything is engraved on the back of this watch.. it's a fake
Rolex engraves a serial number between the lugs.. some fakes duplicate this..but generally not very well.
Lastly if you have none of these issues.. the final way to be sure is to have the back removed and have the movement verified.
Best of luck
