Central air Goodman ck30-1a blowing fuses?
I don't know what you use to heat your house, (heat pump, gas, oil) but if it is not a heat pump, i.e.. you don't use the outdoor unit to produce both heat and cooling, then the first place to look is at the compressor in the condensing unit (outdoor unit). If you have a bad capacitor, it will cause the compressor to pull locked rotor amperage (LRA) for an extended period of time and will cause the fuse to trip (usually within 2 or 3 seconds) The other possibility would be that something got into the wiring and have created a short. I have seen more insect and rodent damage to wires then you can imagine, so this is also a high possibility. Hope this helps
