Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
How do u fix part d967 on hitachi 51f500
Tv turns on but shuts off right away
5 Related Answers
Bill Heronemus
  • 308 Answers
SOURCE: Hitachi 51F500 (Two separate problems?)
My guess is that the sound you heard was that of some High Voltage discharges that could have fed back and damaged some semiconductors including the microprocessor itself. Since it could be a very expensive repair, I would be very tempted to look around for a new HDTV by JVC or Toshiba. Hitachi has slipped a notch or two in recent years according to my experience.
Posted on Jan 28, 2007
Anonymous
SOURCE: hitachi 51f500
I would try throwing it in the trash and purchasing a new television. Just a hunch, but I think that would solve your problems. Good luck!
Posted on Nov 27, 2007
Anonymous
SOURCE: connecting PS2 to a Hitachi 51F500
Sure! My kid is playing her brand new PS2 on ours right now. Just open up the front panel (where the start button is) and hook the three wires there, then choose the 5th input button on the remote.
That is all there is to it.
Posted on Dec 26, 2007
Anonymous
  • 1305 Answers
SOURCE: I lost remote is there away to manually change tv
Unfortunately, most of these projection TV's require a remote. You CAN purchase an aftermarket remote. I would look for one that has all the features you need, PIP, screen format etc.... I have found that the Sony RM-VL600 works real well with my Mitsubishi TV... kids thrashed the remotes more than once...
This particular unit has system control PROGRAMABLE buttons on the bottom row. I've been able to program them for formatting the screen, setting audio and video... Solved my issue of needing a factory remote... KEN
Posted on May 14, 2009
Anonymous
  • 647 Answers
SOURCE: My Hitachi TV Model #51F500 is showing shadows and
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Posted on Nov 05, 2009
1helpful
I lost remote is there away to manually change tv black panels back to full screen like the aspect button without a remote? the tv is a hitachi 51f500
Tv wont power on
I had the same problem Replace the IC's and it should fix this
Tvrepair
Hello my projection screen is cracked and in need to know where i can get it fixed and how much will it cost.
Hitachi 51f500 service menu
I think your convergance amp ic are bad.
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Describe your Hitachi 51F500 51
Hitachi 51f500 magic focus
convergance amp ic bad
Hitachi 51f500
It sounds a lot like a micro/eprom problem and Hitachi addressed this in a service bulletin quite some time ago. Their fix was to add a jumper from I007 pin 1 to cathode of D019... Problems ranged from picture freezing to on/off control without prompting. Not an expensive fix and can easily be done in-home if you get a good reputable shop. We've done several in-home on a simple service call.
Hope this helps!
Bill
Hitachi 51f500
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Ekse
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
