DCS WO-130 Stainless Steel Electric Single Oven Logo
Question about DCS WO-130 Stainless Steel Electric Single Oven
How to install dcs 211708
1helpful
How to calibrate my DCS ovens
hi there.
this is all i could find.go to this link and see if it helps you.
How to calibrate DCS ovens Google Search
Nov 19, 2017 • DCS Ovens
DCS double oven blinking the word "probe" when no
Check your temp probe ans see if it is not up against the wall or jammed of even broken off.
Feb 24, 2013 • Ovens
I have DCS single wall oven model WO127 SS. Display is dim, again. Was repaired in '08 with part #211708. When I look for this part again, it says it fits WO130 with no mention of WO127. Genuine...
Good Morning Mr Villa!
FixYourBoard has repairs what youre experiencing in 2-3 business days. They'd remanufacture your part, and replace your dimming display, fully test the unit.. and back their work with a 2 year warranty. http://www.fixyourboard.com
Mar 30, 2017 • DCS Ovens
Where can I find part no 211696 for dcs oven?
what is this part called and where did you get the part number,then i will help.
10helpful
10answers
Dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
2answers
F7 error message in DCS 27in double electric oven
hello. here is the customer service department info at DCS. Since this unis is new, Irecommend that you work directly with them so as to avoid voiding the warranty
http://www.dcsranges.com/contact.html
4helpful
2answers
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS [email protected] 1-888-281-5698 new Zealand.
4helpful
4answers
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
2helpful
2answers
DCS Single Wall Oven Model WO-130-SS
Order part #211708 from 1-888-281-5698 DCS [email protected] new Zealand. Only need philips head screw driver and twenty minutes. This part is a upgrade for lcd only. old part was a three part system, but no need for three parts only lcd screen.
9helpful
5answers
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Top DCS Ovens Experts
vince
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
