Question about Fisher and Paykel DE09 Dryer
How to open up
I need to put in a back venting exhaust where it currently vents out of the side. I need to open it up and remove the 90 degree elbow and attach a straight vent tube.
5 Suggested Answers
Anonymous
  • 83 Answers
SOURCE: Venting a dryer outside
What do you need to reverse?
I understand that the wall kit is to blow the heated air from the dryer to outside therefore not humidifying the laundry.
Are you trying to draw air into the dryer from outside or blow the air outside?
Posted on Sep 14, 2008
jdhnmi
John Hicks
  • 143 Answers
SOURCE: do you have to use the exhaust with the AMAZING
yes you need to vent it out side
Posted on Jan 27, 2010
Anonymous
SOURCE: Stops drying after short time
I'm no expert. In fact I was having the same issue that your are with the dryer cutting off after running a short time and after googling and coming across your post I thought maybe I had a similar issue. Not so much that I needed a hard line but that the vent duct was clogged and so the dryer built up too much heat. I undid the vent hose and looked into the vent pipe and sure enough it was full of old lint. I was able to go under my house and undo the vent pipe and **** it out with a Webster cobweb brush. Not real easy but not to difficult either. The dryer seems to me much happier now.
Posted on May 15, 2010
awcm
  • 32 Answers
SOURCE: my top load dryer does
Check the exhaust tube, then go to to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Posted on Oct 15, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My dryer is making a
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Jan 24, 2011
Powers on, then immediately shuts off. More detailed in comments below This is too aggravating!!!!!!! Characters characters
Hello Kathy: All clothes dryers work on the same basic principle...
1.) Air Flow
2.) Heat
3.) Rotation
Your problem may lie in your duct work configuration and how the exhaust gases are vented; the mere fact that you had blockage could have overheated the dryer's high limit thermostat and/or the thermal fuse...BUT, before I go any further...I need to talk to you about safety!
Gas dryers give off combustion gases that are toxic and DEADLY; DO NOT VENT YOUR DRYER UNDER YOUR HOUSE SLAB to the outside! Especially that you report that it gets WET inside that underground slab- it's against NFPA fire codes (municipal and state building codes, as well) to do that. If that slab ever collapses partially or fully, you'll have no way of knowing it and the toxic gases will back-up into your house.
The safer venting method should be done with 4 inch solid wall vent pipe; and should be vented directly outside. Maximum duct work (straight run of ducting without the use of any elbows) for your model gas dryer, is 65 feet.
If you are using 1- 90 degree, the total length reduces to 55 feet, including the elbow in that measurement
The use of 2- 90 degree elbows, 47 feet; for 3- 90 degree elbows, 36 feet, and for 4- 90 degree elbows, 28 feet- maximum length.
These are per your manufacturer's installation specifications.
Although you should not use more than 4- 90 degree elbows in your configuration, in the event you do, you would deduct 6 feet for each additional elbow used. You want to make sure that you can visibly see the vent pipe (to visually inspect it for defects or for ease of access to clean and service)- and never keep flammables of sorts near the vent pipe due to the heat that they radiate.
I choose solid vent pipe over foil or plastic (in my home, rental properties, and when I do installs) because lint does have a tendency to burn inside the duct work...which could lead to perforation and/or fire. Plus many manufacturers recommend solid vent pipe over other types; and I do not recommend using screws to connect solid vent pipe together with, since lint can catch on the exposed screw that protrudes into the duct. Use a combination of, heat rated duct tape and dryer vent clamps.
Some installers or readers of this will think that this is excessive, costly, and not necessary; through my life's experiences, I have seen unfortunate yet avoidable tragedies. (Don't forget to check & clean your dryer ducts at least once-a-year!- I do mine at the start and end of DST- the same day we change the clocks and the batteries on our smoke and carbon monoxide detector alarms.)
Now, concerning the rest of the troubleshooting process, are you getting any trouble code errors on the electronic panel? If so, what are they?
You have several choices, you can disconnect and remove the high limit thermostat and thermal fuse and check them for continuity or call tech support using their smart diagnosis procedures as outlined on page 35 of you owner's manual. Or you can disconnect the dryer at it's power source (outlet or circuit breaker) and wait a half hour; see if the electronic computer panel resets. Then try running the dryer.
Please let me know how you made out or if you need more help.
Mar 15, 2015 | LG DLE2240W Dryer
How to change output vent from side to bottom on my Fisher paykel de05-us2 dryer
It should be able to be accomplished by using an adjustable 90 degree elbow you can buy at a local HomeDepot or Lowes. The elbow should be 4" four piece adjustable ell. The radius of the ell should match perfectly with the knockout on the bottom when slipped over the discharge opening of the dryer.
Mar 04, 2015 | Fisher and Paykel Dryers
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Install side vent for GE dryer
Unlike some other dryers that have knockouts on the side and allows the vent to come out the side I don't believe this one does. The air duct has the rear discharge outlet built right into it. Since it sounds like you don't have enough room to put a 90 degree elbow on the back of the machine, which would move the dryer out about 6 in, you might try one of those square duct dryer fittings. See link for example:
http://www.northlineexpress.com/itemdesc.asp?ic=5CO-89638&source=froogle&kw=5CO-89638. If you had to you could put this 90 degrees, and continue it out with retangular metal duct.
Jul 20, 2010 | GE DVLR223 Dryers
Kenmore dryer w/back vent, need to make it vent into floor/bottom
you will go to any hardware or home depot and purchase a metal ductwork elbow. that will direct the vent down 90 degrees
Jul 14, 2009 | Maytag PYE2300AY Electric Dryer
P/N 131456800, side vent exhaust, stackable unit dryer
Just need a piece of 4" straight vent pipe and a 90 degree elbow.
Jul 16, 2008 | Frigidaire FEQ1442ES Electric Dryer
Over Stop Microwave Vent Blower doesn't remove steam
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
The installation instructions are what you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Microwave Ovens
Rudd exhuast and air intake lines
You need to make sureyou are at least 12" above ground with your termination if you live where you get accumulating snow levels. Next, your exhaust needs to be separated from your intake via a "goose neck"(straight pipe out of your house with 90 degree elbow pointed up then attach a 10" piece of pipe with a 90 degree elbow pointed out away from your house. The reason you want to keep them separated is that your intake will **** exhausted air into combustion chamber causing burner lift etc. due to no oxygen to properly burn. I usually put a 45 degree on intake so it is not so inviting to birds etc. Good Luck
Mar 10, 2008 | Heating & Cooling
Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Nov 20, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Fisher and Paykel DE09 Dryer Logo
96 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
