Question about iLO XM-MP3-CD Car Stereo
Stero plays for awile then cuts out - iLO XM-MP3-CD Car Stereo
Car cuts off when stopping
clean your map sensor with a dry cloth very gently install it back if your car does not work proper try an expert mecanic plugt on computer
How do i play my ipod on the stero
You must have a aux input on the RCA. Get a patch cord from radio shack that will patch your ipod to the RCA. They will help you if needed. If you need order online Radio Shack is an authorized dealer of ipod. You can call and ask Questions 1800 843 7422
2answers
My clarian car stero will play the cd player while
It sounds as if the power leads are not connected properly.
Make sure the memory lead is connected to a constant 12+ volt source, and the switched lead is connected to a 12+ volt power source that is controlled by your ignition switch.
Aduz
Electrical problems with the a/c and stero control lights
Check charging system..may have a bad alternator. good
luck
When put in stero mode,the speakers blast out at full volume..
I had the same problem and have solved it bij resetting it.
Try the small hole above the powerswitch.
Good luck.
ELECTRICAL PROBLEM
The prob seems like you have connected the power to your stero from the wrong place. You cut into live a wire for the power, this should be connected at the ACC on your fuse panel. Also make sure you stero has a good ground! Frankster016
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
iLO XM-MP3-CD Car Stereo Logo
Top iLO Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mehandi Husain ...
Tom Chichester
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
