Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Can I fix the keypad - Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
LCD5501Z/KP5501Z Keypad. How do I change the volume?
This appears to be something to do with a home security system? make model (what is is) in all questions please.
Question moved from Cellphones.
Using the LCD5501Z Keypad - DSC
https://cms.dsc.com > download2
PDF
The LCD5501Z keypad shows the status of your security system using an LCD-style display, along with fixed words and numbers.
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
2answers
Some buttons on microwave keypad won't work
Keypad/keypads once faulty cant be fix . Buy a nex keypad
GE microwave says "shorted keypad", what causes this? How can I fix it?
a shorted keypad is when the tiny capacitors across the keypad,become shorted,the only fix is to replace the membrane keypad........no fix
1helpful
My ge jvm1540 over the range microwave is displaying service needed keypad shortage what does this mean
see this steps and follow and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can b
Keypad don't light up
see this causes and fix it. God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
1helpful
Touchpad not working
please see the next step. and fix it. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
How do I program zonig for my Ademco 6148 pad
The 6148 keypad is a fixed english keypad. It is possible to program your system from a fixed english keypad, but it is very difficult. an alpha keypad shows text descriptions of the programming fields. The model number is 6160. If you are doing your own programming, I would suggest replacing the 6148.
When programming, you're programming your alarm panel, not the keypad. The keypad is just an interface to the panel. If you have a tan box in your basement or a closet, that is your panel. There will be a sticker on the inside of the door of the panel that will tell you the model of the panel at the bottom. It will say Ademco Vista 10, 15, 15P, 20, or 20P.
From there you can go to the link below and find the installation and programming manual for your panel.
http://panelguides.com/panel-guides?task=viewcategory&catid=521
Hope this helps.
How to fix nokia6300 keypad problem
If you still in warranty period, claim your warranty to make it fixed. But if warranty time has expired you can change the keypad by yourself or have it repaired by technician. Spare part for keypad is available to replace your broken keypad.
Hope this help
Hi, My keypad does not work anymore, When I press any button on the keypad nothing happens, how can I fix this?
You can try fixing this problem fixing this problem first by pulling your battery out and placing it back in. After this you can try using your keypad once more.
Kind Regards
Top Jenn-Air Refrigerators Experts
john h
Marvin
Marvin
nu267
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
