There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
SOURCE: Beater Bar Quit Working
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
SOURCE: roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
SOURCE: The beater bar does not turn. The belt is fine.
WAIT!!! Don't replace the entire clutch yet... I just had the same problem. Before buying a new clutch assembly, I took the out the clutch just to make sure I could do it (the link previously mentioned is great: http://www.dysonmedic.com/DC07%20Folder/DC07%20Clutch%20replacement.html). In the process, I also opened the clutch at the wide end (two screws and a little retaining clip on the side - can watch a video as to how to disassemble the clutch here: http://www.ezvacuum.com/dyson-dc04-dc07-and-dc14-belt-pack-for-clutch-system-90251401-2-pack-p-2196.html?currency=USD). In the "lid" you will see a little black plate (looks like the same material that a car breakpad is made out of). If the clutch is the problem this plate will look a little worn down. It can be removed and flipped over. You'll get a few more years out of it. Of course, when the second side wears out, you'll have to get a new clutch (but by then maybe the the entire vac will need replacing anyway). Enjoy.
Testimonial: "thanks very much for your insight and practical money-saving tip! Bob"
SOURCE: Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
