SOURCE: cabrio whirlpool washer
you could clean the rps sensor with rubbing alcohol. tip machine back, remove the rotor with al allen wrench. remove the (4) 5/16" bolts holding the stator on, carefully unclip the rps sensor. (Rotor Position Sensor). Remove the wire clip and clean the contacts. Reassemble and give it a try. Or have your dealer ( unless its sears as they WILL NOT help you, call yourself, 800-253-1301) and see if they will give you a one time goodwill gesture to their customer and cover it under warranty. If cleaning doesn't help you need the control board, wire harness, and rps sensor replaced. the rps sensor should come with the new harness. Whirlpool may cover parts????? hope this helps
SOURCE: My Whirlpool Washer Cabrio model# WTW6200SW has a
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
SOURCE: I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
