Roper 24 in. RUD3000 Built-in Dishwasher Logo
A
Anonymous Posted on Jul 09, 2014
How do you make the water drain out of the dishwasher? It is a roper RUD000DBD
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on May 20, 2010
SOURCE: Water in back of Roper dishwasher
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
1helpful
2answers
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
2answers
Water is holding up inside the dishwasher where the water drains
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
heatman101
It won't drain. We just installed a new garbage disposal. Could we have done something wrong?
Did you remember to knock out the hole in the disposal...before connecting the hose you need to take a hammer and screw driver and punch out the knockout in there...
Dishwasher Problems - Water will not drain out
heatman101
heatman101
Roper RUD5000KB1 dishwasher won't drain. Pulled all parts except pump and cleaned, found nothing broke!
when i put on all the dishes and kitchen utensils and turn it on, i saw water is leaking and flowing out from the machine and it suddenly shut down and i cannot turn it on anymore.
Roper dishwasher washes, seems to run normally, but leaves a couple inches of water in the bottom when done
If the drain is stoped this will happen. Is it a new instalation? If into a disposer did you knock out the plug in the disposer. Check the drain line
5helpful
My roper dishwasher won't drain
Check the following to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Water In Dishwasher Won't Drain
heatman101
a
2answers
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Top Roper Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
