SOURCE: Smith Corona Classic 12 ribbon won't stay in place
Okay...i had the same problem when I replaced the original ribbon that came with my Classic 12. I think it was the ribbon that came with the typewriter.
Anyway, on the ribbon carrier, there are two sets of metal prongs on top of one another. If you get the ribbon behind both of them, it will pop up and not go back down or won't come up at all.
You have to get the ribbon between the two sets of prongs. There's isn't much room and you have to kind of pull the bottom of the ribbon taught and slide it down from the top.
It isn't easy the first time, but after you get it, you won't forget.
As for your ribbon not feeding...take the spools out and make sure the pegs that go into the holes in the spools are rotating when you type. This is what moves the spools. Then make sure you're getting the pegs in the hols when you put the spools back in.
Also, make sure the ribbon isn't twisted anywhere and that it's threaded correctly. Both spools should look identical with the ribbon coming out of the top toward the carrier.
To ensure you have the correct ribbon, got to the Office Depot online store and do a search for Smith Corona Classic 12 and you will get a pretty generic, double-black ribbon that fits and works perfectly...and is so soaked in ink you can reuse each side three times. I don't recall the brand name, but the box is grey with red lettering.
SOURCE: smiths corona SL500
Ebay. Smithcorona.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: smith corona wordsmith typewriter model # ka13
The print head might have accummulated a lot of paper bits you need to clear them with a needle or just submerge the tip in petrol or ether. Caution do not submerge if its made of plastic.
SOURCE: My typewriter, an Electra 120 smith-corona, is
This is an old mechanical typewriter, rather than electronic. Thus, the sticky keys are gummed up and quite possibly the rails are gummy as well. Look in your phone book under typewriters. My company to this day has a full-time typewriter repair person, and there should be many such companies out there. Should cost about $75 to repair.
