Question about Taylor & Digital Scale Lithium Scale
Taylor scale started weighing WAY off changed batteries now says oL
5 Related Answers
Anonymous
  • 74 Answers
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
Anonymous
  • 74 Answers
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
timmo53
SOURCE: taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Posted on Feb 08, 2009
Anonymous
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
Anonymous
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
I replaced the batteries and followed the instruction.
You need to initialise the weighing process by tapping your foot on to the scale to start it...but wait for it to zero...then step on it.
Jul 02, 2015 | Taylor 7404 Ultra Thin Lithium Scale with...
Weighing klo and not pounds
Look for a switch on the scale on the bottom or sides and slide it to the lb. side.
Jun 19, 2014 | Taylor 5599 440 Pound Tempered Glass Body...
Hello: my digital food scale (taylor digital biggest loser brand) goes on but it does not weigh anything. its stays at zero. i've had it a year but only used it once or twice, so its almost never been...
Hello, Maclay55 -
I hope you checked the owner's manual first, the troubleshooting / problem solving section.
It wouldn't hurt to put new batteries in the scale (2 AAA batteries).
Note: From the instructions for the scales:
6. Do not store scale where you store cleaning chemicals. The vapors from some household products may affect the electronic components of your scale. Do not store scale on its side.
7. This scale is an extremely sensitive weighing device. In order to prevent run down of the battery, do not store anything on the scale.
8. Do not dispose of batteries in fire. Batteries may explode or leak. Do not mix old and new batteries. Do not mix Alkaline, carbon-zinc (standard) or Nickel-Cadmium (rechargeable) batteries. Remove the batteries if the scale will not be used for a long period of time.
Source:
1037BL The Biggest Loser by Taylor Stainless Steel Platform Scale Instruction Manual, pages 4-5
http://taylor-enviro.com/media/IBs/1037BL_ib.pdf
If installing fresh batteries does not work, then I suggest you call the Taylor USA Consumer Help & Support department. This is the link to the web page with the US and Canadian telephone numbers:
http://taylor-enviro.com/taylor-support/
Best wishes.
Feb 11, 2018 | Taylor Precision Products Taylor Precision...
Scales not working properly- weighing too light with battery symbol dotting across screen - have changed the battery, no difference.
scale may need to be calibrated or you may have something causing the scale to be unstable or something could be binding
Mar 08, 2010 | Taylor Health & Beauty
When I weighed myself 4 times in a row today it read 4 different weights. Is the battery wearing out? What do you think.
hello. Definitely change the battery. Also make sure the scale is on a hard surface, not carpet.
please rate my answer as helpful. thank you.
Feb 23, 2010 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
Hello my taylor 5589 fat scale doesn´t work anymore. each time i weigh myself it says err2. i changed the batteries and it´s still the same.
Had the same problem with mine and sent it back since it's under warranty. Taylor did not need a receipt and I just received a new scale today, model 5742 although it cost me just about $20 to ship it back and that's UPS ground! The scale retails for $29.99 on amazon.com. Good luck!
Dec 01, 2009 | Health & Beauty
Taylor & Digital Scale Lithium Scale  Logo
284 people viewed this question
Top Taylor Health & Beauty Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
