Question about Timex 1440 Nylon watch
Erjwd00017 set alarm - Timex 1440 Nylon watch
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Timex expedition wr100m alarm
    TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
    May 04, 2012 | Timex Expedition Watches
    How do you set a timex ironman wathc and how do you use the stop watch and alarms
    Hi hdirkse,
    To set the digital time and date on your Timex Ironman, please follow the steps below.
    1. press and hold the "set" button for two seconds.
    2. Use the "advance" button to reach the correct hour.
    3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
    4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
    5. When you are finished setting the time and date, press the "set" button to save.
    Setting an Alarm
    1. Begin by pressing the "mode" button until the alarm screen appears.
    2. Press the "set" button and use the "advance" button to set the hour for your alarm.
    3. Repeat the same procedure to set minutes and seconds for your alarm.
    4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
    5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
    Hope it helps.
    Thank you for using FixYa.
    Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
    Coutura Chronograph Watch: set the alarm on a coutura chronograph...
    pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
    or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
    May 17, 2010 | Seiko Coutura Chronograph Watch
    How do i set the alarm on my sieko contura
    May 15, 2010 | Seiko Coutura Chronograph Watch
    How to set alarm
    Seiko chronograph
    May 15, 2010 | Watches
    Alarm
    So the alarm setting is just hidden. To unhide it, just go to the time menu and hold set. With the flashing time, scroll through the menus with the mode button until you get to alarm 1. Then press start/split to unhide it. You can also hide or unhide any of the other menus along the way.
    Aug 15, 2008 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
    Unwanted alarm
    using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
    Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
    Watch isn't recognised by computer
    Hi Hoffman518,
    To set the alarm on your Timex Ironman, please follow the steps below.
    Hope it helps.
    Aug 08, 2007 | Timex Ironman 53151 Wrist Watch
    Timex 1440 Nylon watch Logo
    137 people viewed this question
    Top Timex Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    MrFixitSTTL
    pacdave
    Are you a Timex Watch Expert? Answer questions, earn points and help others
