Battery charger was distroyed and we need a charger for this chair
Gosh I am sorry but have NO knowledge Re: Quantum chair chargers but unless you got your chair and equipment from Scooter Store. which got shut down by Feds due to fraud, you might contact chair's supplier and ask about getting a replacement for your destroyed charger's source.
Failing that, does your city/county publish a "throw away" paper? Sometimes one can find powerchair's equipment posted there. That might be worth a try.
I am sorry not to be familiar with Quantum mobility aids! Anybody else, please?
SOURCE: I got new batteries put
Has the chair been put in "manual mode"? Make sure of this and that batteries are secure.
SOURCE: Jazzy 1200 power wheelchair is electrically
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
I'd look for a loose connection, one battery bad could be it, but its not likely, you can still move it with low voltage, one low batt., could be joystick. You can get generic trouble codes off your joystick, and call the manufacturer, Pride, 1-800-800-8586.
