1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
linda if you have not upgraded your ipod`s firmware please do it because i was facing the same problem,i upgraded the firmware and it fixed the problem.you can upgrade the firmware using itunes and clicking on check for firmware.if the firmware is already upto date then please reload the same firmware.
Hit the menu button, scroll down to date. Use the large button to the right of the viewfinder to move to the right of date. There you will find the date and time. Use the large button again to scroll to time and set it. Take lots of pictures for Christmas!
When you turn your Palm on, on the main page there should be a list of icons. Make sure in the upper right-hand corner All displays with an arrow pointing down.
Then, click on the World Clock icon to change the date/time for your Palm.
the time and date setup should be in the settings menu. open the menu then go to 'settings'. scroll down to 'initial setup' and select this option, then you select time and date. this is where you set up the time and date. :) hope this helps.
