It is an older model with the separate base, also it is the bigger radio
SOURCE: Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
SOURCE: Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION:
disconnect the set from power before opening the case or poking around
inside. The fuse could be bad, but these sets are notorious for losing
the power transformer. If the fuse is ok then you are looking at a
$100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
