Whirlpool Whirlpool duet shows error code e1 f6 what does that mean
4 Related Answers
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
Anonymous
SOURCE: Whirlpool Duet Sport Error Codes?
My machine had the F21 code and the inlet to the pump was blocked with change, bobby pins, small rocks, pieces of fuzz and clothing. Removed the front cover of the mahine and removed the cap on the front side of the pump and cleaned this trap area out. The pump motor quit humming and the machine worked like it is supposed to!
Thanks
Posted on Sep 09, 2009
Anonymous
SOURCE: Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Posted on Jan 16, 2011
rickead1
Rick Ead
  • 1998 Answers
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Posted on Jan 16, 2011
    What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
    Error code F06 means Drive motor tachometer error.
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
    Potential Causes
    1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
    2/ Check the Drive Motor
    3/ Check the MCU
    4/ Check the Wire Harness
    Replace failed component or contact an authorized repair agent.
    Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    What is error code E1 mean
    i'm sure you already found out that you have or had a bad thermister located on top of the blower wheel housing,just answering this in case somebody else has this problem.e1 error code is bad thermister
    Sep 30, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    Ho do I reset the whirlpool error codes f6
    F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
    Potential Causes
    • Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the Drive Motor
    • Check the MCU
    • Check the Wire Harness
    Replace failed component.
    Whirlpool Duet error f6 Google Search
    Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
    F8 E1 error code
    anyone able to tell me what the E1 F8 error code means on a Whirlpool duet steam washer?? it keeps stopping mid cycle...
    Jan 05, 2014 | Jenn-Air Ovens
    Model number wfw9250ww error code e1 and f6
    How to fix a error code of E2F3 on a whirlpool duet model # wfw9250ww00
    May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    Error code E1 what does it mean
    The problem is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in troubleshooting this error code.
    Troubleshooting Error Code E1 on Whirlpool Duet and Kenmore Elite Dryers
    Aug 27, 2011 | Kenmore 62602 Electric Dryer
    Screen flshes e1 f6
    E1 is not an error code on this model. Check to make sure its E1
    F/06 Drive Motor Tachometer Error
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
    • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the MCU
    If you have anymore questions or need further assistance please feel free to comment me back.
    Jul 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Marvin
    Marvin
