Question about Mtd Products Yard Machines 158CC Tiller
How to find replacement clutch cable M T D rear tine tiller with no sereal number
Dennis Pullishy
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 133 Answers
You can do what i did and resoider or re crimp the cable go to the hardware store and buy a generic cable and fabricate your own.i did this for my 2 year old mtb lawn tractor as i was too cheap to spend the 50 buck for a crappy 1/8 thick cable that the manufacter knew was going to fail.I used a spare throttle cable from my vw dune buggy and cut it to fit.
Posted on Sep 09, 2014
5 Related Answers
Anonymous
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
Anonymous
SOURCE: broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Posted on May 13, 2009
Anonymous
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
Anonymous
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
Tom
  • 221 Answers
SOURCE: I have a MTD yard machine rear tine tiller. Goes
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Posted on Jul 01, 2010
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
How easy is it to replace clutch cable on earthquake mc 43 tiller
Remove the 4 to 6 screws holding the engine to bottom gear box and lift eng off. clutch is right there. It could be the teeth on the lower branze gear are stripped. lay machine on its side and with tines off remove gear box cover.
Apr 08, 2013 | Ardisam Inc Earthquake Mini Cultivator
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
Mtd rear tines tiller won't engage tines. F and R
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Broken clutch cable connector, MTD Tiller
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
130 people viewed this question
Top Mtd Garden Experts
Dennis Key
Dennis Key
dannydoesita
Marvin
Marvin
Are you a Mtd Garden Expert? Answer questions, earn points and help others
