with the door sagging it may not be pushing button in far enough to shut light off or aligning with button right.Replace bushings in door.The fuse is probably the same one for light and door locks.
.If you can push the latch in manually, press the clear button while the button is pressed in. If that doesn't clear it:
Try disconnecting the power at the breaker to reset any electronics that might be at fault. (Make sure there are no little graphics of a lock that appear on your screen. If there are and you can't find the source, the shut down should help.
There is sometimes a separate switch aside from the light switch the is on the front of the stove front or very close to the latch itself. Considering that the oven clean will work, if there is one, it appears that is working in the in position. Look around the latch and the front of the oven for any other switches. Clean it if you find a separate control so that it can pop back out when the door is open. ------ hold in the door button and push broil until the latch makes a 360 degree then the door lock should stop flashing and the oven will work again . Hold the lock button for 3-5 seconds.. if the door was open but the lock are latched. Holding the Clear/Off button had no effect. We unplugged the unit. Then while one person held the oven door light switch button in, another person plugged the unit in. While still holding the light switch button in, the Clear/Off button pressed for 10-15 seconds, at which point "locked" appears in the display. Then, while still holding the light switch button in, pressing and holding the Clear/Off button unlock the unit. if still the same problem the door assembly is cracked and that needs replacement.you can get required parts from www.repairclinic.com This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
