Question about Amana ABB1927DE Bottom Freezer Refrigerator
Bottom freezer on Amana BG21 refrigerator is almost the same temp as the top frig.
The frig temp seems to be fine. Fan on the compressor is running fine. Frig seems to be running most, if not all the time. Took out ice maker and back metal panel in the freezer. No frost on this panel. Fan in freezer running fine. Very small amount frost on top right section of coils. Thank you !
Posted by Gary Knebel on
  • Gary Knebel
    Gary Knebel Jul 09, 2014
    In answer to everyone's questions....
    There was just a SMALL amount of frost on the top left section where the freon inlet (or outlet) tube is....including that tube was frosted over.
    I put a small heater in the freezer for a couple minutes and that frost was gone. After I plugged the freezer back in the temp still only got down to 31 overnight in the freezer with it turned up to maximum.
    I will have to check into what the bi-metal is.
    Yes the fan is blowing up in to the refrigerator section and it is getting into the refrigerator.
    Thanks for your suggestions.....Gary
  • Gary Knebel
    Gary Knebel Jul 22, 2014
    I replaced the bi-metal and the freezer section is still not cooling and there is no frost build-up on the evaporator. With the freezer set on max the freezer is 26 degrees and the frig is 36 degrees. Is there any other ideas ? It seems the refrigerator runs most if not all the time. I did cycle the defrost timer and it seems to be working. My next step may be taking that off and actually testing it at the contacts I suppose. What do you think ?
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Freezer cool, but Frig section is not cool
Volman, take a look in the freezer section and see if you have a heavy build-up of frost on the back panel. You want to take the evap cover off and see if the evaporator is frozen up. If so, your refer did not go into defrost and cannot move the air over to the refer side. If this is the case you will have to defrost that evaporator completely. On these Amanas the culprit is usually the bi-metal which sits on the evaporator. Look at it and see if it's buldged. The part number for the bi-metal is ro131661. If you defrost the evap your refer will start cooling again normally until it freezes over again. This will give you time to replace the bimetal....Catriver...post back.
Posted on Aug 21, 2006
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Posted on Aug 28, 2007
Techsim
James
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Anonymous
  • 4 Answers
SOURCE: Amana refrigerator only not working
Have same problem with my basic whirlpool refridgerator 2 months old.  Warranty guy came out.  He said the vents between the freezer/fridge air are clogged with ice.  this happens if the door is left open for awhile which allows water to condensate, then closed, water freezes.
Said to left fridge defrost completely for 24 hours to let ice melt thn plug back in.  I'll update if this does not work.
Posted on Feb 26, 2009
Anonymous
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
GE TFX22P Refrigerator Evaporator Fan
Fun run as long as the compressor runs and you do not need to worry about it. the only thing you need to verify are the temperatures in the refrigerator and and freezer compartment: below 40-F, and below 0-F
if temp ok, do not wory about it.
Aug 18, 2014 | GE Profile 21.6 cu. ft. Side-by-Side...
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
Everything in the freezer has defrosted, temp setting at 6 (refrigerator compartment at 5). Amana bottom freezer model ARB210AB Water will not freeze, ice cream melted and frozen veggies and meat have...
Is there frost on the freezer panel? are the two motor and compressor running (freezer motor and condenser motor)? find this out 1st. this is nothing you did but if you are not mechanically incline at this point only a frig tech can properly check and tell you exactly what is it. theres are the things it might be...
compressor not working
condenser not running
freezer fan not running
thermostat not sensing temp.
stuck in defrost
heaters on too long
bi-metal shorted
timer not working
now if you paid alot for this frig at least get someone to look at it for a service call ($40-60) if it too high to repair then its time to get a new one
Mar 27, 2010 | Amana Easy Reach Bottom Freezer 20.5 cu....
Items in frig freeze
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Here's a diagram of your fridge controls and parts.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177055&diagram_id=1347585#d1347585
Oct 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Lights on in frig and freezer but no compressor or fan running
Remove and test the fan. If it has failed the Compressor may not run.
May 03, 2008 | Amana ABB1921DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
274 people viewed this question
Top Amana Refrigerators Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
