Health & Beauty Logo
j
jacqueline spurrell Posted on Jul 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 3 is showing on my monitor ... What does it mean ?
Its a life brand model # 6359
Level 3:
  • Master 6,688 Answers
  • Posted on Jul 08, 2014
Cindy  Wells
Master
Level 3:
Answers
6688
Questions
0
Helped
3529782
Points
21744
On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
I hope this helps.
2answers
Blood pressure monitor, model a50-CVS. What does error 4 mean?
https://www.microlife.com/consumer-products/blood-pressure/upper-arm-semi-automatic/bp-a50
BP A50 Semi Automatic Blood Pressure Monitor
See page 1 of the manual above with phone numbers to call for whatever country you live in and ask you question. There was not an error 4 in this manual. You might want to call your Doctor's office, and inquire. Perhaps batteries are going bad.
My monitor pressure life source UA 767 show in display error cuf , what mean thats error
The Err CUF probably means that the blood pressure cuff isn't properly arranged on the arm. Check that the cuff is around the upper arm 1-2 cm above the elbow. The hose should be near the center of the elbow. Make sure that a rolled up shirt sleeve is not too tight. Next check that the indicator arrow is in the correct range when the cuff is firmly fastened.
Make sure that you are using the correct cuff for the user. There are different blood pressure cuffs (medium, large, wide-range) available for some blood pressure monitors. If the arrow doesn't line up in the indexed range, use a different blood pressure cuff for the unit.
I hope this helps. I used the information about the A&D Medical UA-767 for some of the trouble-shooting details. See https://medical.andonline.com/product/premium-blood-pressure-monitor/ua-767f and click on the Downloads tab to see the manual for this model. (I suspect the Life Source and A&D Medical products are extremely similar.)
Life brand model 6359 need a manual
Why don't ask at the place you've bought it?
1helpful
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
1helpful
Saturday, April 16 9:55 PMI have a Life Fitness Blood Pressure Monitor and I haven't been able to use it since yesterday evening. I purchased it about 11/2 years ago and needed to get a copy of the...
Error -! Air circuit abnormality. Solution: Measure again
Error -3 Error determining measurement data. Solution: Measure again.
HoMedics is the manufacturer. You can contact their Customer Support Dept 800-466-3342 for an Owners Manual.
Hope this helped you.
I get error codes on the unit. Can you tell me what the error codes mean?
I AM GETTING ERROR 3 ON MY LIFESOURCE BLOOD PRESSURE MOINTOR 7 WHILEPUSHING ON START BUTTON,IT DOES NOT GO AHEAD MORE THEN FIGURE 2 & COMES BACK TO 1 & THEN SHOWS ERROR 3,CAN ANYONE,SUGGEST OR GIVE SOLUTION/REMEDY ON MY MAIL ID:[email protected] I HAD LOST OPERATING MANNUAL & WARRANTY CARD,ALTHOUGH THIS MONITORING INSTRUMENT'S HAVING LIFE TIME WARRANTY,INCLUDING CUFF. THANKING YOU.
H.M.PANDYA.
6helpful
2answers
How do i reset the memory on my model #6719 life brand monitor
Press and HOLD the M button for approx 10 secs. A "CL" will display when memory is cleared.
Lenovo model L171
should work min 3 yrs of life it means technically min 27000 hours of life
34helpful
6answers
What does error 3 on my microlife blood pressure monitor mean?
I have digital blood pressure monitor Model 302 made in japan. It is not working. when start shoes error 3. Please advise
Monitor 422 oil stove error codes
put some lime say about 2 tea spoons with about 3 oz of synthetic 4 cycle engine oil
yhen heat to 188 degrees
pour about a cup of red devil drain cleaner into da mix
add 4 oz's of duck weed then add to fuel
wait a week and then turn on da stove
May 21, 2008 • Ovens
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
