MY SAMSUNG WASHER HAS AN ERROR MESSAGE THAY SAYS E3, AND IT WONT SPIN THE WATER FROM MY CLOTHES
I did an internet search on your error code. I found the following for a 3E code (as opposed to the E3 code you mentioned)...I kept looking and eventually found something for E3:
3E code - Motor tacho fault detected
Can also be caused by be main PCB
If the motor tacho signals are inputted less than 2 for 2 seconds after main drive motor started, this error will occur.
E3 code
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Hope this helps.
This video will help you diagnose the fault on 3e error codes and the video will help you solve the problem hope it helps
I recently had an E3 code appear on my Samsung B1445V washing machine. It appeared after I started a Quick Wash, it would fill with water then stop - the E3 code would later appear.
Prior to it breaking down, it was making loud creaking noises for several months beforehand so it wasn't a surprise when it gave up on me. It turned out that the drive belt had worn out and snapped. The drive-belt connects the motor and the drum wheel (similar to a fan belt in a car). When it broke the flapping belt also cut through several wires of the electrical loom from the motor. Fortunately they were colour coded and I was able to repair these.
After much searching on the Internet, I found a new genuine Samsung 1270 J5 Drive Belt on eBay for Ā£8.44. I had it shipped out by first class post and it arrived the next day. The '1270' is the length of the belt in millimetres, I'm not sure what 'J5' means. You might also see these belts advertised as a 1270 Poly-V drive belt - this is also ok. It's called 'Poly-V' because the belt has 'v' shaped teeth on the inside which fit in the cog of the motor spindle so it doesn't slip off. Whilst browsing online, I noticed a lot of these belts were interchangeable between different manufacturers - if you do buy one of these, make sure it's the correct length '1270mm' and has several 'v' shaped teeth on the inside.
After fitting the belt (very easy - took less than 5 mins and tutorials on YouTube if required), I manually span the drum several times to make sure the belt remained on. I then tried a Spin Cycle and it worked perfectly. Afterwards I felt a bit smug as I did consider buying a new washing machine...I saved myself Ā£Ā£Ā£'s.
If you do try this yourself, here's a few pointers:
1) Drain the machine on 'Drain' cycle. Unplugged from the socket and remove all hoses at rear. With a bowl handy, at the bottom right front of the machine, twist and pull out the small drain hose and remove remaining water. Then twist and pull out the filter - more water may come out.
2) Carefully turn the washing machine upside down. On the bottom there is a white cardboard liner held on by 2 screws, remove these. The electric motor is now visible.
3) Visually inspect the motor spindle to make sure the old drive belt is not tangled around the spindle. Also check the electrical wires from the motor to make sure they're not damaged.
4) It's a confined space to work in so be careful not to scratch and cut yourself on the innards like I did initially. Place the new belt over the motor spindle then half over the drum wheel. Rotate the drum wheel and the drive belt will slip on by itself. Once it is fully on, spin the drum several times by hand from the inside to make sure the belt remains attached.
5) Put the bottom cardboard line back, turn it upright then reattached the hoses etc. Plug it back in and run a 'Spin' cycle to test.
Good luck.
Dean
SOURCE: Samsung P801.washer....Error Message " ED" WHY??
"ED" is a door open error. try Closing the door properly or else there might be jam at the door.
SOURCE: samsung j845 oe error
What you need to be looking at is the water lever sensor. Take the top off by removing 2 screws in the back (Top right and top left). Slide the top off. Now you want to be standing in the front. The front right side is the sensor. Make sure the hose is properly connected underneath. If you have a meter, take a resistance measurement across the two end pins. Should read about 20 ohms or so.
SOURCE: we get an e3 error message and we have no idea
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
SOURCE: samsung washer wf218anb/xaa has code dc and wont
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
SOURCE: Samsung WF330ANW front load washer--was just
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
visit this site it will helpful for washing machinehttps://helpdeskminority.com/category/wa...
