Good Afternoon Friend,
I understand the door locks on your Frigidaire Affinity washer, model# ATF7000E, and the load does not start. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: Frigidaire Affinity ATF7000E Front Load
The control is most likely bad. If lights flash on front let me know which ones and how many as it will sometimes tell me what the failure is. Thanks, please leave feedback or contact me again for more info if you need it.
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
SOURCE: Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
