I got the seven blinks of death. I tried what is advised on the service manual (disconnecting the SU and SD boards from the SC, using the jumper and I got the seven blinks again, which would point to a TNPA5335 board problem). The thing is, I tested, and there is no input voltage on the TNPA5335 board. Since the seven blinks of death means the television is in a protection mode, I juste wanted to know if this protection could prevent the P(MAIN) board to power up some boards (in this case the TNPA5335) or if I could discard a faulty TNPA5335 board and start looking at a power problem, which seems as the most probable cause. I just want to make sure the protection does not deactivate power supply for boards for protection reasons.
As there is LED blinks, the power board is funtioning; and 5V rail is OK. The start-up voltage, that have to come from the main board doesn't. Check for the reason. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
In most cases, the main board might have to be replaced. If so, a firmware update too might be necessary.
