A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The Cruz logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A. NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.) In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
How do I factory reset my Cruz? ... What should I do if my Cruz Reader (R100 Series) will not turn on? ... Why does the headset audio sound strange on my T301? ... How do I connect to the Internet if I don't have Wi-Fi at home? ... through CruzTablet.com or one of our Official Retailers come with a One-year Limited Warranty ...
How do I connect to the Internet if I don't have Wi-Fi at home? How do I remove an ... How can I unlock my R100 or T301 if I forgot the pattern? How does storage ...
Amazon.com, Inc.Jun 19, 2011 - Velocity Micro T301 Cruz 7-Inch Android 2.0 Tablet (Black) ... Caity, Idon't know if this will solve your problem, too, but my ... Everything seems to be working just fine now. .... you have to is reset it and hold the power at the same time until comes back hold it for ... Worked perfectly, thanks for sharing the info!
go here Cruz Accessories then click user guides then scroll down to your model which is the first one on the left second row. click on it and the manual will download to your computer.
What updates? Guessing this is some sort of off-brand android tablet? Most tablets use the google play app to update installed apps and to install new apps.
Hi, you will have to factory reset! Follow these instructions:
take out memory card . press an hold the tiny reset button thats not the mic hole. do it with it off or on might matter try both. an then power it up. go in an reload the os. remotely . it will unpack then reboot.
Factory reset- A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The CRUZ logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen. B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A. NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button. C.) In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
