Epson Stylus  CX5000 InkJet Photo Printer Logo
Quentin Singletary Posted on Jul 08, 2014
Why is the ink light staying on and on button light is blinking. what do i do to make it work?
jimharri
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jul 08, 2014
jimharri
Contributor
Level 1:
New Friend:
Answers
32
Questions
Helped
6118
Points
55
...if your ink cartridge is functional, everything should work...re-seat ink cartridge(s), turn off and then back on...check if software allows a computer screen indication to tell what other problems there are...
Epson Stylus CX3900 not recognizing my new ink cartridges just installed
The Epson printer won't recognize the ink cartridge when you have dried or empty ink, outdated printer drivers, ink cartridge not installed and much more. You can easily fix the Epson printer not recognize ink cartridge issue with simple steps.
·Remove and Reinstall the ink cartridge
·Check the ink cartridge
·Update printer Drivers
If your Epson printer blinks the Red or green lights, that means your printer has some other technical issue. You can fix the Epson printer lights blinking issue with these methods.
Lexmark X2350 All-in-one does not respond to anything. When i plug it into an outlet the power button lights up and stays lit for 10 seconds then blinks once and stays lit for another 10 seconds and blinks...
Your problem lays in to one of the output capcitors in the circuit board. To have it repaired would cost more than purchasing a replacement printer these days.
I would just purchase a new one instead
1helpful
Ihave a blinking black ink indicator light. I have a flashing light on my display ;
Not sure what type printer you have since you didn't mention that, but on most printers when the light is blinking the ink is low, if it stays on solid it is about totally out of ink.
Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
1helpful
2answers
Epson 2200 ink replacement light stays on
I had the same problem with the light black and light magenta as well. It took trying only one new cartridge with the light magenta before it worked.
The light black took 4 new cartridges before it worked. I had called the Epson support center on this problem and after going through suggestions they made that did not work, I told the guy I had another new cartridge on hand. He said to go ahead and try it. This time the printer worked. He took my name and address and said the other cartridges were faulty. Epson is sending me new replacement cartridges at no charge.
1helpful
2answers
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
2answers
Canon MP150
Try holding the Reset button for 5 seconds or more; this may have to be repeated several times.
6helpful
4answers
Canon mp160 prienter alarm light ,power light is blinking&lcd is keep on chngng the nos
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
