Question about Pioneer DEH-P4000UB CD Player
How to fix frmtread error - Pioneer DEH-P4000UB CD Player
000110-0001
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Jul 15, 2013 | Canon Office Equipment & Supplies
Stereo wont play CDs. Screen says FRMTREAD and then ERROR 02. Plays tuner just fine.
hi there
this happens alot with cd players the lens that reads the cd gets dirty and gives you an error message however you can get a lens cleaning cd at wal mart or electronics store and this will clean the lens and then most of the time this fixes the issue however sometimes the lens goes bad and at this point a new player is needed have a wonderful
Aug 23, 2011 | Car Audio & Video
My Pioneer WMP/MP3 is saying frmtread error 11 What is this? Thanks Solve It!
Error 11 on your Pioneer DEH-P3500 CD Player shows that the CD inside cannot be read properly by the player.So please eject the disc and clean it properly.If the error is shown again then there is no way other than replacing the disc because it may be scratched severely.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 14, 2011 | Pioneer DEH-P3500 CD Player
When I try to play a C.D. on my system it says frmtread error
That error is (Format Read Error). Usually a MP3 problem when the disc was burned too fast, or corrupted during burn. Some writing programs dont put an initial track on the CD designating it an audio disc. I have seen Nero have many Problems with this. FYI
Try burning 1x speed on the next disc, yes slow, just to see if it works. If so then gradually increase the burnning speed up again.
Mar 28, 2009 | Pioneer DEH-P4500MP CD Player
CD doesn't work. LED readout says FRMTREAD, error 12. ;what's happening?
If this error appears on any music CD (burned or store-bought), it's likely the laser/lens assembly is having trouble focusing well enough to read the disc. You can try resetting the unit (use a paperclip or ballpoint pen to press the button in the small hole next to the eject button), but there's only a small chance this will help. You could also take it to an electronic repair shop to see how much a cleaning would cost (usually more than the player).
If it only happens on burned discs, try changing brands of CD-Rs or even burning the disc at a slower speed. If the songs are burned from iTunes, try burning other formats (i.e. MP3) via a different method.
Mar 16, 2009 | Pioneer DEH-P6800MP CD Player
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
When I try to play a C.D. on my system it gives me the following information. FRMTREAD, Error 15. What does this mean and what do I do to correct this problem? My system is a DEH2000MP S.N....
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
Jun 23, 2008 | Pioneer DEH-P2000 CD Player
Pioneer DEH-2750 says FRMTREAD when you put a CD in,,it plays CD for 20 seconds then stops,,HELP PLEASE,,thanks Phill
 Pioneer DEH-2750 says FRMTREAD when you put a CD in,,it plays CD for 20 seconds then stops,,HELP PLEASE,,thanks Bibily
Mar 16, 2008 | Audio Players & Recorders
Pioneer DEH-P4000UB CD Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
