Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
F-3 fault control - Kenmore 40494 / 40495 / 40499 Electric Single Oven
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Hi I need a list of error codes for an Angelo Po Combi oven. Model number is FCV101EDS
F0 - No Alarm Signal
The main control board in your oven has failed to communicate with the alarm. This is most likely a fault with the control board itself, which may need replacing.
F1 - Door Not Locking
If there is an issue with the door lock in your appliance you may see this error code. Check the door lock and the wiring and connections to it to get to the cause of the fault
F2 - Door Not Unlocking
The opposite fault to the above, this fault indicates your oven door won't unlock. Once again you'll need to check the door lock mechanism and its wiring and connections. This fault could also be down to the oven thermostat as this could be giving an incorrect temperature reading, preventing the door lock from being released.
F3 - Self Test Error
Turn off your appliance, unplug it for five minutes or so and plug it back in again. Doing so should clear the F3 error code. Easy as that!. If it does not clear the problem you are likely to have a fault so see the links to our diagnosis videos below.
F4 - Temperature Sensor Fault
If you see this error code you'll need to check your temperature sensor and the wiring and connections between the sensor and the main control board. You may need to replace the sensor.
F5 - Control Board Error
This fault suggests a problem has developed with the main electronic control board in your AEG oven. It may need replacing to bring your machine back to full working order again.
F7 - Mains Supply Issue
You'll see this fault if your oven has detected a problem with the power coming into it. This could mean your appliance has been wired in incorrectly. You'll need to check the mains supply connection to your oven to get to the bottom of this error code.
F8 - Power Supply Issue to Control Board
The main control board is not receiving power as it should. Check the wiring and connections to it. If all the connections are fine, you'll possibly need to replace the control board.
F9 - Processor Auto Resetting
As with error F3, turning off and unplugging your appliance for five minutes before plugging it back should reset and fix this fault code.
Oct 24, 2016 | Combi Ovens
F2 shows on display on whirlpool gas stove
Keyboard Failure
Error Code: F 2
Component:
To localize the fault - disconnect the switches from the display unit. If the fault is gone - replace the switches.
Touch buttons - replace control panel assy
Tactile switches - replace control panel assy
Dado
May 14, 2014 | Whirlpool RBS305PDS Electric Single Oven
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
Continuous beeping with F7 fault code. What do i need to replace, the touch pad or controller?
Hello, Thank You for using FixYa. I will be helping you today.Turn off power unplug ribbon cable from touch pad to control turn power back on and if after an hour no error code replace touch membrane if you get a fault replace control (clock Erc)
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Jenn-Air Ovens
15 year old ge profile with f1 fault code. what is f1code.thanks
f1 is usually a control error fault usually means the control board has to be replaced in the unit this is what it says in the service manual for your error GE Gas or Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
how to distinguish between a fault with the touch pad and the control you would have to take and disconnect the power to the unit first and then unplug the touch pad from the control and then replug the unit in for 5 minutes if the error code is still there then you have a defective electronic control if it is not then you would have a defective touch pad it is very rare that you do get both that are defective all at once if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue to help others in similar situations in the future Thanks again I await if you have any further reply
Rick
May 04, 2011 | Ovens
Im trying to set my oven on bake its beeping and reads f4 on the screen??
F4 usually relates to a temperature sensor fault. Meaure the temp sensor at ambient temp and it should measure approx. 1K . If it doesn't, then replace. However, and a big however, I've seen frequent faults such as these where the control board is at fault. The proper procedure is to verify the sensor though first before replacing control board.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore Ovens
The oven was continuously beeping last night. Hit everything on the display setup to try to get it to stop. Eventually it shut off all together(the beeping and display) not the only thing that is showing...
Ok. this is a control fault. the chip set is damaged. this will usually happen when there is a surge or power failure during a storm or faulty transformer on the outside pole. you Will need to replace this damaged Electronic control board if possible . it has failed.
You can confirm my diagnosis by cutting the power to the oven for 5 minutes. this will reset the control. if the oven continues to react this way with the constant beeping and, non action, this will confirm major control failure..It is possible that this reset will recognize the program and fix this fault but, normally, a fault of this nature will require the replacement of the Oven control board.
Jun 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
85 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
