Need to replace the remote receiver in the fan - have a generic Home Depot type and want to wire in . Thanks
SOURCE: need a replacement fan speed potentiometer.
Okay -- first off, I don't know where she got that number from, but that's idiotic.
The variable-speed switch will provide different readings depending on where it's turned to. If the switch is busted ("open), it will typically display a reading of 'infinity' on your ohmmeter.
And yes -- the best place to find a replacement is Radio Shack, since Casablanca discontinued them.
HOWEVER---
Casablanca's variable-speed ceiling fans -- specifically the "SlumberQuiet" ones, which were made from circa 1980 or 1981 to the early/mid 1990s when variable-speed was discontinued -- are well-known for breaking down. The problem is almost never the potentiometer (variable-speed dial). Rather, the problem is almost always the resistor which is mounted in the heat-sink inside the fan's motor housing. There are NO replacements left for these -- so Casablanca makes a "variable-speed to 3-speed conversion kit", which will convert your fan to a more normal 3-speed pull-chain (hi-med-low) setup.
I hope that helps! If you have any other questions, please feel free to ask!
SOURCE: our casablanca ceiling fan has
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
SOURCE: Casablanca Ceiling Fan
I've never heard of the light and reverse buttons being reversed. Normally It's the fan and light thats swapped (but your aware of that already). I would try a working w-32 from one of the other fans. There's also a shop called Fan Man Lighting in Minnesota who has a guy named Jason who has been fixing fans for over 20 years, He helped me with my Casa problems. Their website is www.FanManLighting.com Hope this helps.
SOURCE: Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
SOURCE: I have a Casablanca Intelli touch ceiling fan.
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
