Question about Danby DAC9003D Air Conditioner
What is the lever on the vent which labels open or close for on a danby dac9003d air conditioner
5 Related Answers
Anonymous
  • 540 Answers
SOURCE: Danby Air conditioner
Check out the co. website, for that unit and codes for troubling shootings! Thank-you-very-much!
Posted on Aug 27, 2008
Dennis Boxerman
  • 1306 Answers
SOURCE: danby portable air conditioner
https://www.danby.com/registration.php?ln=USE&
Go to this web site to register your product.
Posted on May 20, 2009
Anonymous
SOURCE: It's 102F outside and the Danby dpac120068 air
I have heard other people do this I am not sure
Posted on Sep 05, 2009
Anonymous
  • 36 Answers
SOURCE: Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
Posted on May 27, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Danby DPAC7599 Air Conditioner is not blowing cold
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
Should the air vent lever be pushed in to get fresh outside air on a danby dac12010E air conditioner?
I don't think anyone is really understanding what you are asking. I had the same question with a Danby AC. For everyone else, this person is not asking what the switch does, they are asking if the "in" position is vent. This has a little plastic manual push/pull lever that the manual calls a vent switch, but does not specify which position of the switch is for what, and its all internal so you can't see what's going on.
My best guess is that pushing it in is vent, with my only reasoning being that the switch stops when pulling it in, but I've seemed to manage pushing it in too far, going past the intended stop. That leads me to believe that I'm just over opening it. I don't think I could over close it.
7helpful
2answers
What is the setting for the push-pull lever on the right side of my in-window air conditioner? thanks
If you want to pull fresh air into the room and not use the cooling part of the unit. pull the lever out. If you don't want to introduce fresh air into the room during the cooling cycle, push the lever in.
Thanks for choosing FixYa.
Goldstar R1003 Could you explain the use of the vent lever?..
Vent closed for best cooling.
Vent open to exhaust stale air.
How can you make your conditioner cool to 40 degrees
ACs are designed to cool down to about 68^F, don't think it has a chance of doing what you want w/o re-engineering the system which is not really an option.
5helpful
Describe your Kenmore Air Conditioner Proble. My
the vent is a fresh air intake, when it is pulled open you are mixing outdoor air in the unit. when it is hot and humid outside you will make the unit struggle to cool. Leave the vent closed.
5helpful
2answers
Code flasing!!
CLEAN YOUR FILTER THEN UNPLUG YOUR UNIT AND REPLUG IT AFTER ABOUT A MINUTE
2helpful
Should i open or close
Close the vent for maximum cooling. When you open the vent it opens a panel to the outside air and the unit cools less efficiently.
There may be a starting delay built in, which will not allow restarting within 5 or 10 minutes. Other than that, the control unit may be faulty & require replacement.
Danby DAC9003D Air Conditioner Logo
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
Tim Whalen
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
